Si sway bar endlinks compatible with ITR?
Old Nov 17, 2004 | 02:05 PM
EMphaticONE's Avatar
Default Si sway bar endlinks compatible with ITR?
looking into putting a 23mm ITR rear sway bar on my 00 Si. will my endlinks bolt up?
Old Nov 23, 2004 | 04:57 PM
8krdline's Avatar
Default Re: Si sway bar endlinks compatible with ITR? (pearlblueb16)
yes
Old Nov 23, 2004 | 09:50 PM
fishnfst's Avatar
I believe that the threaded portion of your si endlinks are smaller than the ITR bushings in the swaybar. I purchased some custom machined aluminum bushings from A-specracing.com to fit 99=00si endlinks onto my itr sway bar..
Old Nov 23, 2004 | 10:06 PM
bananaek's Avatar
yes but beware!!!!!!!!!!!!!!! the body thickness was increast on the CTR.
us cars are slimmer and 23mm sway bar may/ well rip you're rear crossmember
i've seen people weld extra metal to re-inforce the metal
Old Nov 25, 2004 | 07:24 AM
8krdline's Avatar
Default Re: Si sway bar endlinks compatible with ITR? (DELUSIONEK4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DELUSIONEK4 &raquo;</TD></TR><TR><TD CLASS="quote">
i've seen people weld extra metal to re-inforce the metal</TD></TR></TABLE>
Yea, you may want to get the reinforcement kit from beaks
http://beaksproducts.com/Products.htm
Old Nov 25, 2004 | 08:57 AM
bananaek's Avatar
Default Re: Si sway bar endlinks compatible with ITR? (8krdline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8krdline &raquo;</TD></TR><TR><TD CLASS="quote">
http://beaksproducts.com/Products.htm</TD></TR></TABLE>
t/y thats good info
aemintgsr
Jan 19, 2008 05:09 PM
jeffk182
13
Oct 26, 2006 01:32 PM
cambopheonix56
Mar 10, 2006 03:34 PM
null.
Aug 7, 2004 12:31 PM
speedemon
Jan 4, 2004 09:33 AM
