D15 - D16 swap info??
Old Nov 17, 2004 | 01:47 PM
yenpit's Avatar
Default D15 - D16 swap info??
First ??.......92-95 D15 block.......will the D16 Y8 Vtec head bolt on to the 1.5L block?? This is a budget build for this guy, thus the D15 block.
Second........can someone direct me to the best info link for this swap??
Thanks in advance!!
Old Nov 17, 2004 | 02:03 PM
civiccpedx's Avatar
Default Re: D15 - D16 swap info?? (yenpit)
i would try doing a search, and/or posting in the hybrid forum. but to my knowledge, which isn't to great on the mini me swap, is that it should bolt on.
Old Nov 17, 2004 | 02:04 PM
lohatch's Avatar
yes you can do it......hit up bauleycivic
Old Nov 18, 2004 | 07:23 AM
klungemonger's Avatar
The swap is pretty basic, just like changing a headgasket. It's good to get the larger Y8 intake manifold with the head also, but your stock one will fit alright. Here's a couple tips:
1) You need to get headbolts or headstuds for the Y8 engine.
2) Get yourself a 92-95 Si or EX engine harness
3) Get a P28 engine computer, it plugs right in ready to play
4) There *might* be an oil control jet on top the block ib a hole at the back between the 2 middle cylinders, if it's there pull it out before installing the new head.
Old Nov 18, 2004 | 07:26 AM
cnyej1's Avatar
Default Re: (klungemonger)
Here is everything you will ever need to know:
https://honda-tech.com/zerothread?id=635580
Old Nov 18, 2004 | 07:43 AM
simplypinoyy's Avatar
Default Re: (cnyej1)
dude i had this swap and its great, the torque and acceleration on this thing was amazing i wish i never swapped it out but it had too... i burned oil :-( ... Compared to the d16z6 that i have in rite now i'd choose the mini me over it anyday
:mini-me:
Old Nov 18, 2004 | 10:24 AM
yenpit's Avatar
Default Re: (simplypinoyy)
Thanks ALL<U></U> for your input!!! I'm gonna pursue the above link, but if anyone has any input on the potential issue for proper timing on this particular swap (as I 've heard may be a problem), post up!
Old Nov 18, 2004 | 09:19 PM
Default Re: (yenpit)
Problems: THe only one that I had was the fact that my head burned oil... couldnt figure out why
EJeff8
12
Oct 3, 2013 08:02 PM
lil_Ek9
Jan 7, 2005 03:51 PM
Hipnotic
Oct 5, 2003 08:48 PM
grncivic91
Jun 12, 2002 03:24 PM
