What else should I change while I'm doing suspension and brake work?
Old Nov 17, 2004 | 09:38 AM
litterbox's Avatar
I am a (Trial User) Army
Default What else should I change while I'm doing suspension and brake work?
Hey,
I'm swapping my suspension and brakes with Koni/GC and Teg brakes next week.
<U>Question:</U>
What other parts are worthwhile to replace while I'm down there?
Thanks.
Old Nov 17, 2004 | 09:40 AM
ScubaStevo80's Avatar
Default Re: What else should I change while I'm doing suspension and brake work? (litterbox)
swaybars would be a good upgrade if you don't already have them.
Old Nov 17, 2004 | 09:43 AM
litterbox's Avatar
Default Re: What else should I change while I'm doing suspension and brake work? (VolpeOwnsU)
Sway bars are sitting in the garage ready to be put on. Forgot to mention that.
I'm thinking more along the lines of upgrading parts that have just worn out because of years of use.
I've heard about changing the tie rod/tie rod ends? Can someone explain this?
Anythine else that should be changed. I wanna do this right the first time
Old Nov 17, 2004 | 09:49 AM
SOHC4life 96's Avatar
Get some nice new b00shings. Energy suspension would be a good choice.
Old Nov 17, 2004 | 09:50 AM
Team 4R's Avatar
change your brake fluid..... go with ate super blue
Old Nov 17, 2004 | 09:55 AM
ISawUL00k's Avatar
replace all the bushings. make sure the shock mount bushing is firm. as well as the bushinngs at the arm to body. control arm bushings can be fixed with prothane inserts but the others may require a machine to be pressed out/in..
Paint calipers and getsome slotted front rotors.
also its a good time to scrape all the shiz off the inner fenders. an roll ur fenders to if ya going to go low with 205's or wider.
There was a myth that the 4 door rears handbrake cable is to long but its is all the same. i got 4d00r Ls rear and it was a direct bolt on other than i had to use a peice off the old arms 2 14's and a T thing.. you will see what i mean.
Drop ur gas tank.
good luck
pdiggitydogg's Avatar
tie rod ends would be good, I guess.
Theyre not hard, just dont screw up the distance from the actual rod
Old Nov 17, 2004 | 10:09 AM
litterbox's Avatar
Default Re: (pdiggitydogg)
K, So far I'm looking at changing:
All Bushings
Tie Rod Ends
Is there anyone that sells a complete bushing kit? Or do I have to get new OEM ones?
Old Nov 17, 2004 | 10:37 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (litterbox)
Here's my "how to" on tie rod ends...
https://honda-tech.com/zerothread?id=1031874
Replace your rotos w/ some brembo blanks.
Replace all caliper hardware.
Clean & relube all sliding pins.
Mabey add SS brake lines.
Paint Calipers.
Replace Rear LCA bolts and coat non-threaded surfaces w/ anti-siez.
Old Nov 17, 2004 | 10:38 AM
POE's Avatar
POE
im not sure if this was said but ,dont forget your camber kit
Default Re: (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">K, So far I'm looking at changing:
All Bushings
Tie Rod Ends
Is there anyone that sells a complete bushing kit? Or do I have to get new OEM ones?</TD></TR></TABLE>
Energy Suspension sell them individually or as a kit.
If you want a little firmer brake, get some SS brake lines.
Old Nov 17, 2004 | 10:49 AM
litterbox's Avatar
Default Re: (DOHC4life)
Here's what I've ordered so far. This is all going during Thanksgiving:
Integra Brakes all around
Goodridge SS Brake lines
Koni Yellow/GC Combo
Here's what I have already:
Omnipower front and rear camber kits
Here's what I need to get:
Tie Rod ends
Bushing kit
LCA Bolts
Where can I get the energy suspension bushing kit? Can anyone think of anything else that might be useful?
Thanks for all your help guys
Old Nov 17, 2004 | 10:50 AM
litterbox's Avatar
Default Re: (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">Here's my "how to" on tie rod ends...
[/B]</TD></TR></TABLE>
Thank you very much for this. I was looking for it.
Old Nov 17, 2004 | 11:07 AM
INCNTRL4's Avatar
Bushing kit's are a god, I got one for the delsol, defintly come in handy when you replace stuff incase you break a bushing. I know I did, thank god I got the kit.
Mishako129
Jun 10, 2012 10:03 AM
EFstyle
Mar 13, 2008 10:19 AM
madmanmaigret
13
Aug 1, 2007 05:09 PM
xoutlawz00x
May 20, 2005 12:11 AM
Backmarker
23
Jul 23, 2002 07:52 PM
