zc rod/piston swap into z6
Old Dec 27, 2001 | 12:13 PM
BenenEK's Avatar
Default zc rod/piston swap into z6
Info needed? zc piston and rod swap into d16z6 motor-
comp ratio?
bad idea?
Old Dec 27, 2001 | 01:17 PM
agent marlon's Avatar
Default Re: zc rod/piston swap into z6 (BenenEK)
i had a few engine builders recommend putting zc pistons into a D16, will increase compression ratio but not too sure how much..maybe a few points..you could do that or you could just mill your head.
Old Dec 27, 2001 | 04:31 PM
Mista Bone's Avatar
D Tranny Guru
The rods are the same, but the pistons have the wrong dome shape to fit under a Z6 head.
It will crash.
You can use the ZC pistons under a A6 non VTEC head and get about 10.7-11.1 compression.
[Modified by Mista Bone, 8:31 PM 12/27/2001]
92hatchboi
Oct 21, 2007 06:16 AM
GarageAlchemist
Jun 12, 2007 08:28 AM
GarageAlchemist
13
Mar 9, 2007 12:45 PM
1point7db2
Oct 4, 2005 02:52 PM
hybridmike
Oct 5, 2002 12:40 PM
