Question regarding power steering removal
I found no problems turning in crx w/ out power steering. of course its much lighter than itr. In comparison, how much more effort will be needed in itr with no power steering?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidnyc »</TD></TR><TR><TD CLASS="quote">The effect is much easier if you vent the power steering as discussed in one of the power steering "how-to's" on this board. </TD></TR></TABLE>
yep.. padawan's kit works well and is pretty easy..
David, is that what you used?
If the car is rolling, the difference is small. But the difference during parking is much bigger.
And it depends how strong you are. If you are strong, the difference is relatively small....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stationwagon »</TD></TR><TR><TD CLASS="quote">drain what fluid ? what if you just took off the p/s belt, do you have to remove the whole unit?</TD></TR></TABLE>
the power steering fluid
if you take off just the belt steering can be tough. if you take off the belt and remove some of the fluid it's much easier. even easier to add a breather.
you don't need to remove the whole unit but can (should) for weight savings.
read more here
read more here
CTR_B
Aug 31, 2008 02:05 PM
