Front Swaybar/LCA
Hey guys, I already searched, but can only find info regarding 'teg LCA's or rear setups. I have a '93 CX with no factory swaybars. I have a 24mm GSR front swaybar and want to know if civic ex/si front LCA's will work with this bar. Also, with a 24 mil front bar, what should I run on the rear? I'm not autocrossing or anything, but I want the car to handle like a go-cart
. Thanks in advance
. Thanks in advance
you will need lca for the front from si, ex or gsr. as for the rear you will need lca from gsr or si, if you not autox or anything stock front and rear will do. as the bigger rear sway you are running into risk of tearing your sub frame. you will need proper bracing susport like beak kit, or comptech sway/tie bar combo.
thanks for the replies guys! As for the rear LCA's, I'm going with aftermarket. Does anyone know anything about those ebay Megan Racing lcas? I've already looked into the beaks subframe reinforcement kit, that will definitely be a must-have before rear swaybar installation. Also, I was wrong on my front bar, it's 22mm not 24. Which rear to run with the 22mm front? I was thinking maybe stock integra size [14mm?]. Also, just to clarify, EG Civic Front LCA's *will* work with an Integra swaybar and endlinks, correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CivicSI »</TD></TR><TR><TD CLASS="quote">5th gen hatches did not come with sway bars.... - You will have to get rear LCA's from a teg...</TD></TR></TABLE>
si hatch does come with the front not the back.
EK99hatch
Sep 15, 2006 07:32 AM
JDMTurboCivic11
Jan 25, 2005 07:06 PM
95integragsr1984
May 25, 2003 09:26 PM
