Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Anyone using the Quaife steering rack yet?
Old Nov 17, 2004 | 08:49 AM
n1div's Avatar
Default Anyone using the Quaife steering rack yet?
I see it available on the Quaife site and was wondering if anyone has done this or currently using one that can comment on the installation/modification and characteristics of it.
Old Nov 17, 2004 | 09:03 AM
locash's Avatar
Default Re: Anyone using the Quaife steering rack yet? (n1div)
I've got a handful of them in stock, and Brian Hasty from Fastbrakes is installing one in his k24EG right now, we'll try to keep you updated..
Old Nov 17, 2004 | 10:47 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Anyone using the Quaife steering rack yet? (locash)
Can sombody confirm the presence the pressed on pinion bearing?
When I e-mailed quaife, they said it doen't come w/ it. In contradiction, somone one here said they know for sure it does...
WTF?
Old Nov 17, 2004 | 11:07 AM
Mr Hammond's Avatar
a/k/a Jomo
Curious too.
Anyone disassembled a steering rack before? Manual one doesn't seem to difficult.
2.831 L-T-L
Old Nov 17, 2004 | 04:47 PM
ShaunRR's Avatar
HT White Ops
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locash &raquo;</TD></TR><TR><TD CLASS="quote">I've got a handful of them in stock, and Brian Hasty from Fastbrakes is installing one in his k24EG right now, we'll try to keep you updated..</TD></TR></TABLE>
His car continues to sway me towards the K24.
Old Nov 17, 2004 | 08:48 PM
eg6vtec1's Avatar
its not fast enough, what like 2.8 lock to lock verses stock 3 not worth it. I ran a 1.5:1 steering quickner in my eg wich made it 2 turn lock to lock, it was all right but not fast enough, now i run a 2:1 quickner 1.5 lock to lock, Its so bad *** i cant even describe it. you have to run power steering though, and all the orfices have to be drilled out to speed up the power steering ram.
Old Nov 17, 2004 | 09:19 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Anyone using the Quaife steering rack yet? (eg6vtec1)
can you please explain how a "steering quickner" works? This is new to me, and sounds interesting. I don't like the added P/S though...
Old Nov 17, 2004 | 09:43 PM
Victor Penner's Avatar
Default Re: Anyone using the Quaife steering rack yet? (94eg!)
Yes, please fill us in.
Thanks,
Victor Penner
Old Nov 17, 2004 | 10:17 PM
ShaunRR's Avatar
HT White Ops
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">can you please explain how a "steering quickner" works? This is new to me, and sounds interesting. I don't like the added P/S though...</TD></TR></TABLE>
I have wondered this as well.
I would also like to know who makes these for Hondas?
Old Nov 17, 2004 | 10:24 PM
revolt_allmotor's Avatar
Default Re: Anyone using the Quaife steering rack yet? (rochesterricer)
i think they are universal you install them inline with the steering shaft or whatever its called. the piece that goes from the steering wheel to the rack. you just shorten that piece and install the quickener between it and the rack.
at least thats how the one i saw looked it was on an SRT4 rally car...
Old Nov 17, 2004 | 10:34 PM
eg6vtec1's Avatar
you have to remove and fabricate a new steering column, the steering quickner is a small gearbox with splined shaft on each end, one end go's to the steering wheel and the other go's to the steering rack, a 2:1 ratio quickner means for every one revolution on the steering wheel side of the quickner is two revolutions on the steering rack side, so if your steering is 3 turn L2L, now will be 1.5 L2L
Old Nov 17, 2004 | 11:29 PM
94eg!'s Avatar
#1 Super Guy
Loved
So the addition of the P/S is just to compensate for the added steering effort.
Old Nov 17, 2004 | 11:44 PM
eg6vtec1's Avatar
yes, double the steering speed meens double the effort, and also takes the stress off the new fabricated steering column and steering qiuckner wich is very high without p/s.
Old Nov 18, 2004 | 04:10 AM
H5Civic's Avatar
Anyone checked the CCR or GCR to see if these are allowed?
Old Nov 18, 2004 | 04:58 AM
Chris Sawatsky's Avatar
New User
just make sure you don't install it backward. 6 turns LTL!
Old Nov 18, 2004 | 05:26 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6vtec1 &raquo;</TD></TR><TR><TD CLASS="quote">you have to remove and fabricate a new steering column....</TD></TR></TABLE>
i would be all over this for my civic if it wasn't illegal for SM. if they change the lower subframe allowance, i will install one as i can lower the rack in a custom subframe, but until then i will have to contend with an integra rack.
Old Nov 18, 2004 | 06:38 AM
n1div's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6vtec1 &raquo;</TD></TR><TR><TD CLASS="quote">its not fast enough, what like 2.8 lock to lock verses stock 3 not worth it. I ran a 1.5:1 steering quickner in my eg wich made it 2 turn lock to lock, it was all right but not fast enough, now i run a 2:1 quickner 1.5 lock to lock, Its so bad *** i cant even describe it. you have to run power steering though, and all the orfices have to be drilled out to speed up the power steering ram. </TD></TR></TABLE>
According to the fastbrakes website, it brings it from 4.2 down to 3.2. That is a big difference. Not sure where you got your numbers from.
BTW, the Quaife unit that is currently available for the civic's are only available for manual racks.
Old Nov 18, 2004 | 08:06 AM
94eg!'s Avatar
#1 Super Guy
Loved
The 88-91 CRX is 4.1 stock down to 3.25, and the 92-95 Civic & 94-01 Teg is 3.6 stock down to 2.81. This info is taken from Quaife's 2004 price list. I guess Fastbrakes doesn't have their info right...
Old Nov 18, 2004 | 09:02 AM
DB2-R81's Avatar
25 Year Member
This looks quite nice, any idea how it performs?
Old Nov 18, 2004 | 09:15 AM
Rodney's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote"> 94-01 Teg is 3.6 stock </TD></TR></TABLE>
the 94-01 teg is 2.98:1 stock.
Old Nov 18, 2004 | 09:26 AM
Xian's Avatar
Default Re: Anyone using the Quaife steering rack yet? (rodney)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodney &raquo;</TD></TR><TR><TD CLASS="quote">
the 94-01 teg is 2.98:1 stock. </TD></TR></TABLE>
Yep.
The 92-95 Civic is 3.6-ish...
Old Nov 18, 2004 | 09:39 AM
RPM's Avatar
RPM
Who makes a good steering quickener?
Old Nov 18, 2004 | 09:40 AM
clemsonhatch's Avatar
Default Re: Anyone using the Quaife steering rack yet? (Xian)
I just ordered one and I will be installing in a week or two...I'll let you guys know
Old Nov 18, 2004 | 10:11 AM
Xian's Avatar
Default Re: Anyone using the Quaife steering rack yet? (clemsonhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clemsonhatch &raquo;</TD></TR><TR><TD CLASS="quote">I just ordered one and I will be installing in a week or two...I'll let you guys know </TD></TR></TABLE>
Ordered the Quaife parts? Cool. Let me know how it works out!
Old Nov 18, 2004 | 10:50 AM
Jaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">The 88-91 CRX is 4.1 stock down to 3.25, and the 92-95 Civic & 94-01 Teg is 3.6 stock down to 2.81. This info is taken from Quaife's 2004 price list. I guess Fastbrakes doesn't have their info right... </TD></TR></TABLE>
Have a look at the Quaife site. They list the 88-91 new parts as being 2.8:1 and the 92-95 at 3.25. Boy, I hope thats right, though I know they (Quaife) originally told me the opposite.
http://www.quaifeusa.com/suspension/suspension.htm
And the 88-91 EF stock is 3.88:1 for the manual rack. I also think you might be thinking of the power racks for the 92-95 when you say 3.6 stock, as I'm pretty sure the manual one is 3.88-4.1:1.
