jumpy idle
I just put a b18c1 in my honda it has 11:5:1 compression ported and polished head skunk2 cams and cam gears stage 2 with aem fuel rail and regulator and knife edged crank. since i got it hooked up it has not idled normal the idle is jumpy is that normal for my setup or is there a problem? i have a chipped p72 ecu also. help please!!
same thing happened to my H22......just take out the fuse for the ecu to reset it........i did a couple months ago and its idled fine and i havent lost any power or had any problems since.
the cams and cr are not going to make the car idle rough enough to notice. I would take some brake clean and spray it everywhere on the intake manifold and see if the idle goes up or down.
disconnecting the battery wont do it.......but in my H22 all i needed to do was open up the fuse box in the engine and it was a red fuse with 10 on it and labeled 10A clock radio on the fuse box. take that one out if you dont have a fuse labeled ecu, just leave it out for a few minutes and stick it back in, it did wonders for me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bboy21385 »</TD></TR><TR><TD CLASS="quote">what is the TPS sensor? whats it do wheres it at?
TPS = Throttle Position Sensor
Its on the back of the TB facing the firewall!
escourt23
11
Dec 2, 2005 08:14 AM
Crisgo
Apr 7, 2004 08:06 AM
