need info on lock cylinders for 90' da
Old Nov 16, 2004 | 08:41 PM
hatchinprogress's Avatar
Default need info on lock cylinders for 90' da
guys plz bare with me im really new to the teg's i just bought a '90 ls and the pass. side door lock was "jammed" and i need to replace it i got a new cylnder but i know that i will need to get it re-keyed, does anyone know how much that should set me back? and also how can i go about installing it? thank you for any info
Old Nov 17, 2004 | 08:09 AM
Default Re: need info on lock cylinders for 90' da (hatchinprogress)
bump for help
Old Nov 17, 2004 | 01:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress &raquo;</TD></TR><TR><TD CLASS="quote">bump for help</TD></TR></TABLE>
Old Nov 17, 2004 | 05:58 PM
can anyone help i dont want to have to go to the dealership
Old Nov 18, 2004 | 10:16 AM
ttt
Old Nov 18, 2004 | 04:24 PM
damn no luck bump
Old Nov 18, 2004 | 05:54 PM
2gturboteg's Avatar
buy a lock cylinder out of a junk car somewhere. then take it to a locksmith withthe key and lock cylinder from the good side. he will be able to rekey it to work with your cars existing key. probably less than 75 bucks for everything.
Old Nov 18, 2004 | 06:01 PM
Default Re: need info on lock cylinders for 90' da (2gturboteg)
how can i remove the bad one from the car?
Old Nov 20, 2004 | 08:29 PM
2gturboteg's Avatar
remove the door panel and then take out the two bolts that hold the handle in unclip the rods and remove handle. after it is out you will see a small silver clip that holds in the lock cyl. remove the clip and the lock cyl will pretty much fall out.
Old Nov 20, 2004 | 09:16 PM
chamoru's Avatar
You will need to remove the glass to make it easier. it's not hard just takes time.
small hands will be good.
Old Nov 21, 2004 | 11:28 AM
Default Re: need info on lock cylinders for 90' da (chamoru)
thanks 2gturboteg for info and to chamoru as well
sixtodc4
Nov 26, 2008 06:11 AM
monkey_boi
Feb 27, 2008 05:54 PM
HondaSivik
Honda S2000
51
Jul 6, 2006 11:20 AM
Rusty Shackleferd
May 5, 2005 08:29 AM
eg6h8k
Jul 8, 2003 03:40 PM
