K24a2 TSX hybrid Dyno sheet.
Old Nov 16, 2004 | 06:20 PM
HotWheelz's Avatar
Default K24a2 TSX hybrid Dyno sheet.
I figure a couple of you would like to see this..
premium 5 speed!!!!!
Stock internal TSX engine (no type-R cams)
Comptech RACE header (with custom motor mounts)
2.5 exaust with Greddy muffler (bolted)
shortram intake with K&N filter (mounted)
overbored TB
Hondata IMG gasket
STOCK Type-S manifold (not gasket matched) <-- last minute
K-Pro (partial tune)
Conservative timing, 90 octane mixed regular and premium...
VTC - confidential but very mild
AF reading tuned per RPM.. (changes for best result)
3 baserun passes, 6 passes for changes, one last pass with cam angle change. only had 1 hour, had appointment something to study mostly.
non vtec map not changed, HUGE POWER TO BE FOUND! look at the flatline (VERY BAD!!)
7400rpm is not enough, this motor could see 8000++ and torque doesn't fall as fast as Brian's motor.. "possibly due to header???"
better IM (ITR) and a CAI with better tunning could be a 230whp engine without touching internals!
VIDEO
http://personal.nbnet.nb.ca/tuned/after.WMV
Old Nov 16, 2004 | 06:42 PM
Nikos's Avatar
WOW!!
All I can say is WOW
Great job and thanks for sharing.
Old Nov 16, 2004 | 06:43 PM
UnKnownUser's Avatar
Default Re: (Nikos)
!!!WOW!!!
Old Nov 16, 2004 | 06:47 PM
Kamin's Avatar
Default Re: (LSVTEC_DC4)
holy **** a honda with a real torque band!
Old Nov 16, 2004 | 07:36 PM
99B16Si's Avatar
holy crap thats nice. whqat do these motors do bone stock out of the box?
Old Nov 16, 2004 | 09:14 PM
Mr.OB*GYN_Rhett's Avatar
Default Re: (99B16Si)
amazing power , ill probably regret buying a R when these hybrids are being built for half the price and kicking my ***
Old Nov 16, 2004 | 09:16 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: K24a2 TSX hybrid Dyno sheet. (HotWheelz)
Are those Dynojet numbers? Very nice.
Old Nov 16, 2004 | 10:35 PM
see_our_vtec's Avatar
Default Re: K24a2 TSX hybrid Dyno sheet. (rochesterricer)
something is wrong, torque and hp should be crossing at 5252, not 5800ish. either the dyno is messed up and isn't correcting, or it is a fake graph. power looks right though.
Old Nov 16, 2004 | 11:02 PM
JDMorgan's Avatar
Default Re: K24a2 TSX hybrid Dyno sheet. (see_our_vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by see_our_vtec &raquo;</TD></TR><TR><TD CLASS="quote">something is wrong, torque and hp should be crossing at 5252, not 5800ish. either the dyno is messed up and isn't correcting, or it is a fake graph. power looks right though. </TD></TR></TABLE>
how do you know he doesnt have an aftermarket ecu?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HotWheelz &raquo;</TD></TR><TR><TD CLASS="quote">K-Pro (partial tune)</TD></TR></TABLE>
Old Nov 16, 2004 | 11:08 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: K24a2 TSX hybrid Dyno sheet. (KraZEtEggIE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KraZEtEggIE &raquo;</TD></TR><TR><TD CLASS="quote">how do you know he doesnt have an aftermarket ecu?</TD></TR></TABLE>
It has nothing to do with the ECU, it has to do with the way horsepower is calculated.
Old Nov 17, 2004 | 06:03 AM
DaiJekBok's Avatar
The torque graph is plotted against a different scale (which is cut off of the right side in the image). Look at the printed numbers for torque peaks and where they fall on the graph against the scale on the left and this becomes clear. I've got a ton of dyno graphs for my old car where the two lines never meet because the scales were so off.
Also, my god that is sweet.
Old Nov 17, 2004 | 06:54 PM
Alberto's Avatar
Default Re: K24a2 TSX hybrid Dyno sheet. (DaiJekBok)
How come I see the torque reading above 200 but it only shows 181wtq as the max?
Old Nov 17, 2004 | 06:59 PM
Default Re: K24a2 TSX hybrid Dyno sheet. (Alberto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alberto &raquo;</TD></TR><TR><TD CLASS="quote">How come I see the torque reading above 200 but it only shows 181wtq as the max? </TD></TR></TABLE>
I just noticed that too?
Old Nov 17, 2004 | 08:01 PM
ShaunRR's Avatar
HT White Ops
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaiJekBok &raquo;</TD></TR><TR><TD CLASS="quote">The torque graph is plotted against a different scale (which is cut off of the right side in the image). Look at the printed numbers for torque peaks and where they fall on the graph against the scale on the left and this becomes clear. I've got a ton of dyno graphs for my old car where the two lines never meet because the scales were so off.</TD></TR></TABLE>
As he said, the tq scale is off to the right, out of the picture.
Old Nov 17, 2004 | 09:47 PM
spectacle's Avatar
I couldn't hear VTEC in the video??? :dunno:
sounded good tho
Old Nov 17, 2004 | 10:41 PM
Also, my god that is sweet.</TD></TR></TABLE>
good call man, most graphs i see usually are plotted equal, allways throws me off when the scales are unequal.
Old Nov 18, 2004 | 09:58 AM
JB20VTEC's Avatar
nice
Old Nov 18, 2004 | 03:52 PM
Alberto's Avatar
Default Re: (JB20VTEC)
Have some TSX swaps if anybody wants
Kenpo
35
Feb 13, 2008 08:50 PM
pomansouth01
10
Oct 7, 2005 09:09 AM
carboy_honda
10
Jun 12, 2005 05:59 AM
sackdz
Mar 9, 2004 11:00 AM
