DJ STUFF FOR SALE OR TRADE
Old Nov 16, 2004 | 05:54 PM
Paperweight's Avatar
Default DJ STUFF FOR SALE OR TRADE
http://pg.photos.yahoo.com/ph/...ZV4NO
Up for sale is:
staton sk2f fiber optic mixerThe SK-2F is a SK-2 modified with the new revolutionary Focus Fader. It is a true optical fader. Simply put, this means the fader glides without any contacts to slow it down or cause wear from friction. This fader provides 3 major improvents for skratchers: 1) the fader is the fastest available. It glides with little friction. 2) the fader curve (on/off) is super sharp. On/off happens faster allowing for cleaner sounding skratches. 3) because there are no parts rubbing up against each other, wear is minimal meaning this fader should last much longer (no bleeding and static) than any other faders available.
• SK-2 Fader included.
• Bar graph LED meter similar to those found on high end studio equipment.
• Hamster switches and curve adjustment for the crossfader and each channel fader.
• Powerful 3 band EQ (-26, +9dB) and left/right balance for each channel.
• Headphone master output preview, and improved, louder headphone amp.
• 1 mic input with 3 band EQ (+/-10dB).
• 1/4" and RCA outputs
• 10.25"w x 14.5"h x 3.14"d
1Pioneer CDJ-800
FEATURES
Quick Return
Enables a track to return instantly again and again to a cue point just by pressing the surface of the Jog Wheel.
Auto Beat Loop
Uses 4 timing buttons to instantly create perfect 1, 2, 4, or 8 beat loops. When a loop has been produced manually with the loop in and loop out buttons, this feature allows instant 1/1, 1/2, 1/4/, 1/8 beat cuts of the initial loop.
"Wide" Pitch Control
DJ's can use the +/- 100% pitch control range to create new sound effects from opposite ends of the sound spectrum and also to BPM match completely different tracks.
Vinyl Rotating Center Display
Indicates current play position. 135 frames for one rotation.
The Display is animated showing the direction of play either
forward or reverse.
Quick Return Play (New)
This button, when activated, allows the user to return to the
cue point simply by touching the jog dial giving the DJ
more creative options.
Extended Master Temp (+/-10%. +/-100%)
Pioneer's legendary Master Tempo feature offers +/- 10%
and +/- 100% range.
Extra Fast Track/Song Search
Turning the Jog Dial with the press of the Track Search or
Search button allows higher speed search. This function is
convenient for CDs with many tracks or for songs that have
an extended length.
16 second Memory Buffer Shock System
Sound jumps or skipping is prevented by using a 16 second
shock-proof memory for normal CD play (minimum of 10
seconds if scratching in vinyl mode).
SPECIFICATIONS
System: Compact Disc Digital Audio System
Disc Format: CD,CD-R and CD-RW
Frequency Response: 4 Hz-20kHz
Signal-to-Noise Ratio: 115 dB or more (JEITA)
Total Harmonic Distortion: 0.006% (JEITA)
Audio Output: 2.0 V
Power Requirements: AC 120 V 60 Hz
Power Consumption: 21 W
Dimensions: 12" (W) x 13-9/16" (D) x 4-5/16" (H)
2 Gemini XL 100 direct drive turn tables
1 Sony Mini disc recorder
some records
Scratch Dvd
2 how to DJ book(let)
scratch CD
2 Gemini speakers
1 Gemini mixer
All together I spent over $2000 on this stuff. But, my car is more important right now so I am willing to sell it for 1000 OBO.
or I will trade for hondata s200 with a p28 ecu, or CRX 2.5" exhaust, or obd0-ob1 conversion harness, or d16 sohc vtec clutch and flywheel.
i live in a suburb of chicago. mail me at bloodypiranha@yahoo.com if interested
Paperweight
Nov 22, 2004 02:21 PM
sleeperb
Feb 18, 2003 05:36 PM
