Anybody know what this part is called??
Old Nov 16, 2004 | 04:47 PM
AlphaQup's Avatar
Default Anybody know what this part is called??
I need to know what #36 is called. I need six of them for my lip.
BTW: where can I get some online? I dont wanna get em from the dealership if I can get em cheaper online.
Old Nov 16, 2004 | 04:49 PM
GR_DC2's Avatar
go to http://www.acuraautomotiveparts.org, and look it up, you'll get that exact diagram, w/ the numbers, and it'll tell u the name of each part by numbers.
Old Nov 16, 2004 | 04:57 PM
AlphaQup's Avatar
Default Re: (Aznspeedracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aznspeedracer &raquo;</TD></TR><TR><TD CLASS="quote">go to http://www.acuraautomotiveparts.org, and look it up, you'll get that exact diagram, w/ the numbers, and it'll tell u the name of each part by numbers.</TD></TR></TABLE>
Thanks, but I already tried that to no avail.
Take a look at the pic that they have, its different. I doesn't show the peice I need.
http://www.acuraautomotivepart...y.jsp
Old Nov 16, 2004 | 05:12 PM
GR_DC2's Avatar
Default Re: (AlphaQup)
i see what you mean, when u select "bumper" there is no labelf or #36....well in that case, print out the picture, and take it to your nearest dealership. They have these explosion diagrams as well, and can easily tell you what part it is.
Old Nov 16, 2004 | 05:21 PM
AlphaQup's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aznspeedracer &raquo;</TD></TR><TR><TD CLASS="quote">i see what you mean, when u select "bumper" there is no labelf or #36....well in that case, print out the picture, and take it to your nearest dealership. They have these explosion diagrams as well, and can easily tell you what part it is.</TD></TR></TABLE>
Yeah, I know but, I just wanted to find out if they were sold online. Thanks for tryin to help mang.
Old Nov 16, 2004 | 05:28 PM
dFreezy's Avatar
that part is called "CLIP, NUT (6MM)" and is part number 90306-SF1-000. The reason it wasn't showing up is because it goes to the lip which was an option on all the 94-97 integras except the type r. if you choose your car as type r on the site, it comes up.
Old Nov 16, 2004 | 06:07 PM
stumpyf4's Avatar
Default Re: (dFreezy)
You can probably substitute some u-spring nuts and some sheet metal screws.
http://www.aboveboardelectroni...U.htm
These should be readily available from your local hardware store. Pick a large size and you should be good to go.
Basically #36 is thicker metal and has a nut welded onto it and uses a machine screw.
Old Nov 16, 2004 | 06:50 PM
a1320addict's Avatar
im assuming its what my cf lip is bolted to...dont know the exact name...but my car was getting serviced today and i did see that there were six rectangular looking pieces on the under chasis of the front bumper...hope that helps
Old Nov 16, 2004 | 07:20 PM
wreckedmyteg's Avatar
Default Re: Anybody know what this part is called?? (AlphaQup)
Screw 36...where can I get a number 6?!?!
Old Nov 16, 2004 | 07:54 PM
AlphaQup's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dFreezy &raquo;</TD></TR><TR><TD CLASS="quote">that part is called "CLIP, NUT (6MM)" and is part number 90306-SF1-000. The reason it wasn't showing up is because it goes to the lip which was an option on all the 94-97 integras except the type r. if you choose your car as type r on the site, it comes up. </TD></TR></TABLE>
Right on brotha
Old Nov 17, 2004 | 01:32 AM
nub.96ek's Avatar
That is most likely a dealer-only part.
efficiencyJunkie
May 6, 2007 10:05 AM
BolivianDc2
Jul 12, 2005 01:06 PM
ludewithanh22
May 17, 2005 09:23 PM
sPaRk'iT
Mar 30, 2004 02:30 AM
UnCaNnYChInO
Mar 10, 2004 03:20 PM
