CAN YOU USE SATURATED INJECTORS ON A 98 5th gen
Old Nov 16, 2004 | 04:13 PM
caliprelude3087's Avatar
Default CAN YOU USE SATURATED INJECTORS ON A 98 5th gen
i really need to know if i can use the set of brand new 550cc saturated rc injectors on my 5th gen. i've had mixed reports to this subject. are there other people out there that have used saturated injectors on there preludes or other H22s?
thanks
Old Nov 16, 2004 | 04:26 PM
Keith's Avatar
Default Re: CAN YOU USE SATURATED INJECTORS ON A 98 5th gen (caliprelude3087)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by caliprelude3087 &raquo;</TD></TR><TR><TD CLASS="quote">i really need to know if i can use the set of brand new 550cc saturated rc injectors on my 5th gen. i've had mixed reports to this subject. are there other people out there that have used saturated injectors on there preludes or other H22s?
thanks</TD></TR></TABLE>
5th gens use saturated injectors already (OEM)...
Saturated injectors has a slower response time (and closing time) than a peak and hold injectors. If you use peak and hold injectors, you'll need an external resistor pack...
Old Nov 16, 2004 | 05:15 PM
PrettyLude's Avatar
you will need something to control the bigger injectors
Old Nov 16, 2004 | 05:54 PM
safe driver's Avatar
Default Re: CAN YOU USE SATURATED INJECTORS ON A 98 5th gen (Keith)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Keith &raquo;</TD></TR><TR><TD CLASS="quote">
Saturated injectors has a slower response time (and closing time) than a peak and hold injectors. If you use peak and hold injectors, you'll need an external resistor pack...</TD></TR></TABLE>
which essentially turns the peak-hold injectors into saturated injectors
Old Nov 17, 2004 | 12:18 PM
Boost3d22's Avatar
the 550cc injectors are being used for what? n/a ? turbo , nitrous? if so how many psi?
1. honda injectors are high impedence saturated injectors (oem)
2. never listen to anyone who says dsm injectors will work on your honda with out any modification, they are peak and hold and low impedence which requires a resistor pack that hacks up your injector harness.
3. the 550cc injectors can be controlled by the stock ecu.. you dont need a remapped ecu to controll them... if you go any higher then you will need a EMS
Old Nov 17, 2004 | 01:16 PM
JT's Avatar
JT
Default Re: CAN YOU USE SATURATED INJECTORS ON A 98 5th gen (Boost3d22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boost3d22 &raquo;</TD></TR><TR><TD CLASS="quote">the 550cc injectors are being used for what? n/a ? turbo , nitrous? if so how many psi?
3. the 550cc injectors can be controlled by the stock ecu.. you dont need a remapped ecu to controll them... if you go any higher then you will need a EMS</TD></TR></TABLE>
1. Wrong. Some early Honda uses low impedance injectors. That's why they have the resistor box.
3. Wrong. You will not even idle for more than 30 mins without getting a Code 45 with the stock ECU. Where do you get your info anyway?
Old Nov 17, 2004 | 01:20 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: CAN YOU USE SATURATED INJECTORS ON A 98 5th gen (JT)
yeah most (I think all) obd1 hondas are peak and hold type.
Old Nov 17, 2004 | 06:29 PM
RICDOGG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JT &raquo;</TD></TR><TR><TD CLASS="quote">
3. Wrong. You will not even idle for more than 30 mins without getting a Code 45 with the stock ECU. Where do you get your info anyway?</TD></TR></TABLE>
will a code be thrown on an obd1 ecu with 440cc injectors?
Thanks
Old Nov 17, 2004 | 09:45 PM
JT's Avatar
JT
Default Re: CAN YOU USE SATURATED INJECTORS ON A 98 5th gen (RICDOGG)
Yes. If you have 240cc stock injectors, then you will see the CEL very quickly.
Old Nov 17, 2004 | 10:00 PM
RICDOGG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JT &raquo;</TD></TR><TR><TD CLASS="quote">Yes. If you have 240cc stock injectors, then you will see the CEL very quickly. </TD></TR></TABLE>
thanks for your response...however i was asking about RC 440cc injectors
Old Nov 18, 2004 | 11:40 AM
JT's Avatar
JT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RICDOGG &raquo;</TD></TR><TR><TD CLASS="quote">
thanks for your response...however i was asking about RC 440cc injectors</TD></TR></TABLE>
I understood your question. If your stock injectors are 240cc and you are replacing them with 440cc. The ECU will continue to fire the injectors with the same duration as stock injectors, which means the engine will be flooded with more fuel than it can burn. The O2 sensor will signal the ECU to trim fuel as it's detecting rich A/F condition. But once the max fuel trim is reached, ECU triggers a CEL.
Old Nov 18, 2004 | 01:27 PM
PrettyLude's Avatar
and the light would be for running too rich
97 Sleeper
Jul 9, 2008 05:20 AM
doodooheadfart
Feb 22, 2007 09:53 PM
Diversion
Jan 30, 2002 06:48 PM
