Car won't go into gear when its started. Grinds...its like the clutch won't disengage.
Old Nov 16, 2004 | 02:41 PM
Circuit Star-29's Avatar
Default Car won't go into gear when its started. Grinds...its like the clutch won't disengage.
What might it be boys?
Old Nov 16, 2004 | 03:14 PM
Ekay Jay's Avatar
Default Re: Car won't go into gear when its started. Grinds...its like the clutch won't disengage. (nathan a
Shift forks maybe?
Old Nov 16, 2004 | 04:16 PM
Maybe...And it sqeeks alot. Really weird.
Old Nov 17, 2004 | 09:24 AM
bump...help me figure this out. I don't want to pull the tranny and not know where to go.
Old Nov 17, 2004 | 12:26 PM
JimBlake's Avatar
Hydraulic? Try bleeding? It could be external. How much does the shift fork move when you pump the pedal?
How about listening real good & pinpointing the location of the squeaking.
After ruling out external (easy) stuff, it might be a bad pilot bearing.
Old Nov 17, 2004 | 12:59 PM
aznballer's Avatar
if its cable, check the line that goes from tranny to clutch pedel that can unscrew and come loose
Old Nov 17, 2004 | 09:30 PM
Default Re: (aznballer)
Its not cable its HYDRO...And a bad pilot bearing? How might that make this happen?
Old Nov 18, 2004 | 12:30 AM
korean_teg's Avatar
Default Re: (nathan atwell)
ditto on pilot bearing. classic symptoms. Just got a new clutch when I had the same probs you did. That squeaking gets annoying doesnt it? lol
Old Nov 18, 2004 | 04:02 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nathan atwell &raquo;</TD></TR><TR><TD CLASS="quote">...And a bad pilot bearing? How might that make this happen?</TD></TR></TABLE>Excessive friction in the pilot bearing acts exactly like a dragging clutch.
Start the engine with the tranny in gear, clutch disengaged (pedal down). It's making the noise, right?
Release the brake; does the car try to move? If so, that's a dragging clutch or pilot bearing.
Hold the clutch disengaged; shift into neutral. Does the noise stop? Better yet, does it sound like it coasts to a stop? The clutch or pilot bearing drags the input shaft up to it's speed.
Since you have to remove the transmission for this, you may as well get a new clutch, pilot bearing, & throw-out bearing.
Old Nov 18, 2004 | 07:16 AM
The-LS's Avatar
what happens when you start the car in first gear with the clutch pedal engaged? I had a similiar problem before. The clutch was gone, I broke a spring with too many launches... debris from the broken spring acted to keep the clutch engaged SOMETIMES.
Old Nov 18, 2004 | 08:02 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Excessive friction in the pilot bearing acts exactly like a dragging clutch.
This sounds like the problem. Its on my friends civic and we just dropped a motor in that we bought from an HT member that said it was in "Perfect" condition. Well, Ill be pullin' the tranny this weekend. Thanks for your help everybody.
Old Nov 18, 2004 | 08:11 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nathan atwell &raquo;</TD></TR><TR><TD CLASS="quote">... Well, Ill be pullin' the tranny this weekend. Thanks for your help everybody. </TD></TR></TABLE>Then you'll see what it is. Basically, a warped disk, seizing pilot bearing, or springs falling apart in the clutch or PP; they all sorta cause the same problem. Maybe hearing the noise firsthand someone can tell the difference. But since you gotta pull the tranny anyway, just get it all.
Old Nov 19, 2004 | 12:55 PM
Well, just so you now...there is a noise like...squeek-squeek-squeek-squeek-squeek... really fast and it gets louder when the clutch is engaged. We'll find out...thanks so much for your input.
Slowass2dr
May 21, 2007 08:02 AM
vietnamese0utlawz
Oct 11, 2006 04:53 PM
omg_miiiike
Jul 30, 2005 09:07 PM
joestud
Jun 24, 2004 04:37 AM
NaughtyKnight666
Aug 29, 2003 04:23 PM
