will buying a b series mount kit........
if i was to get a hasport mount kit or avid etc.. will that make it so i no longer need to use misc. mounts from misc. cars for me to swap a b-series into my 5gen coupe?
yeah, you just call em up, tell em your car and the engine you wanna put in, and theyll give you some (kickass) mounts. all you do is replace the ones you got and it should fit up well.
my Hasport h22-ek mounts are incredibly beefy. they cost a bit more than most other companies, but i think they're well worth the extra money.
yeah,just tell them what motor you're using(B-series into a 5th gen civic),and they'll set you up.you will still need the Integra rear "L" bracket though.i'd go with Hasport-i've used a ton of their mounts and always had better luck than other brands.
Chris
Chris
spun Vtec
Mar 4, 2003 03:30 PM
89 CRX SI
21
May 2, 2002 06:08 PM
