Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
NASA Race Car Inspections.
Old Nov 16, 2004 | 02:15 PM
Grumpy's Avatar
New User
Default NASA Race Car Inspections. - Northern Virginia
All NASA Race cars will require an annual inspection for the 2005 season before they will be allowed to participate in competition.
I will perform inspections for anyone who wants one at my shop by appointment ONLY starting December 15, 2004. These inspections will satisfy your 2005 annual inspection requirement.
I will also perform inspections at YOUR location for the right incentive.
This is a chance to get them done in time to get any corrections (if necessary) made before the first race.
Interest???
Old Nov 16, 2004 | 07:06 PM
paRRRker's Avatar
Default Re: NASA Race Car Inspections. - Northern Virginia (Grumpy)
so nothing carries over from the late 2004 season inspections?
Old Nov 16, 2004 | 07:09 PM
Hunter's Avatar
Default Re: NASA Race Car Inspections. - Northern Virginia (paRRRker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paRRRker &raquo;</TD></TR><TR><TD CLASS="quote">so nothing carries over from the late 2004 season inspections?</TD></TR></TABLE>
what do u think ********?
NO!
brand new season
need new inspections
Old Nov 16, 2004 | 08:24 PM
Sean O'Gorman's Avatar
This is why I've never encouraged my little brother to post on any car forums.
Old Nov 16, 2004 | 08:36 PM
paRRRker's Avatar
Default Re: (Sean O'Gorman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sean O’Gorman &raquo;</TD></TR><TR><TD CLASS="quote">This is why I've never encouraged my little brother to post on any car forums. </TD></TR></TABLE>
i do not claim him as my brother...i did not see anything wrong with my question...i was just teched in august...dont see why it cant carry over :shrugs:
Old Nov 16, 2004 | 09:37 PM
mstewar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grumpy &raquo;</TD></TR><TR><TD CLASS="quote">All NASA Race cars will require an annual inspection for the 2005 season before they will be allowed to participate in competition.
Interest???</TD></TR></TABLE>
i might take you up on this if a)i come out to VIR in February(assuming the full course will be run then again) and b) i haven't found someone closer to do it..
i don't think you want to come out here to look at mine.. hehehe..
Old Nov 17, 2004 | 01:49 AM
Back in Black's Avatar
Rather OG
Default Re: NASA Race Car Inspections. - Northern Virginia (mstewar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstewar &raquo;</TD></TR><TR><TD CLASS="quote">i might take you up on this if a)i come out to VIR in February(assuming the full course will be run then again) </TD></TR></TABLE>
Another ITR in the field? Sweet! Do it, man!
Old Nov 17, 2004 | 03:39 AM
H5Civic's Avatar
Jim, I know you and I discussed this at the last event at Summit, and I just wanted to reclarify that a X-brace by itself will not be acceptable in 2005 as rear support for a cage. I remember that you said that the rear down tubes may have no more than 15 degrees of angle from their connection points between the main hoop and the rear of the car. Sill correct? Thanks again.
Sam
Old Nov 17, 2004 | 05:09 AM
Kaan's Avatar
Loved
Community Favorite
Default Re: NASA Race Car Inspections. - Northern Virginia (H5Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H5Civic &raquo;</TD></TR><TR><TD CLASS="quote">Jim, I know you and I discussed this at the last event at Summit, and I just wanted to reclarify that a X-brace by itself will not be acceptable in 2005 as rear support for a cage. I remember that you said that the rear down tubes may have no more than 15 degrees of angle from their connection points between the main hoop and the rear of the car. Sill correct? Thanks again.
Sam</TD></TR></TABLE>
thats correct i'm not grumpy but if you need an anual tech i'll see you in the tech shed the first race of the year!
Old Nov 17, 2004 | 06:32 AM
CRXSiR71777's Avatar
Default Re: NASA Race Car Inspections. - Northern Virginia (MMsportsRexSi)
Can someone explain this 15 degree thing. I dont get it.
Old Nov 17, 2004 | 07:07 AM
Drew M's Avatar
New User
Default Re: NASA Race Car Inspections. - Northern Virginia (CRXSiR71777@aol.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXSiR71777@aol.com &raquo;</TD></TR><TR><TD CLASS="quote">Can someone explain this 15 degree thing. I dont get it.</TD></TR></TABLE>
The down tubes coming from the top of the main hoop to the rear shock towers can have no more than a 15 degree deviation away from 90 degrees side to side. Technically the 90 degree angle would be "0" but sometimes it is easier to understand if you think of the downtubes starting at completely perpendicular which would be right (90 degree) angles on both sides of the tube.
Old Nov 17, 2004 | 07:12 AM
Kaan's Avatar
Loved
Community Favorite
Default Re: NASA Race Car Inspections. - Northern Virginia (Evil Drew M)
if your main hoop is the horizontal plain (and it should be)... the main hoop is 0 degrees.... you might want a protractor... and turn it upside down to visualize. the down tubes have to be in between 75 and 105 degrees from the mainhoop (0 degrees).
Old Nov 17, 2004 | 07:22 AM
Crack Monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MMsportsRexSi &raquo;</TD></TR><TR><TD CLASS="quote">if your main hoop is the horizontal plain (and it should be)... the main hoop is 0 degrees.... you might want a protractor... and turn it upside down to visualize. the down tubes have to be in between 75 and 105 degrees from the mainhoop (0 degrees).</TD></TR></TABLE>
Or, another way to think about it... the downtubes have to be within 15* of parallel to the fore/aft centerline of the car.
Old Nov 17, 2004 | 07:23 AM
SJR's Avatar
SJR
hmmm, actually, the main hoop would be the vertical plane (not plain, btw).
here's another way to look at it:
cut off the roof off the car, and look down into it from above. The main hoop would look like a line "---------------", and the down tubes like "|" if they are at 90deg.
THe down tubes can vary from "/" to "\" by 15 deg in each direction.
Any easier to visualize?
Old Nov 17, 2004 | 09:52 AM
H5Civic's Avatar
Default Re: NASA Race Car Inspections. - Northern Virginia (SJR)
Great job of wording it in an easier to understand manner. Thanks to all for confirming what I had already believed to be true.
Sam, who is off to do some cage work some time in the near future.
Old Nov 17, 2004 | 10:06 AM
mstewar's Avatar
Default Re: NASA Race Car Inspections. - Northern Virginia (Jason Franza)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jason Franza &raquo;</TD></TR><TR><TD CLASS="quote">
Another ITR in the field? Sweet! Do it, man!</TD></TR></TABLE>
that's the plan anyhow..
Old Nov 17, 2004 | 10:42 AM
.RJ's Avatar
.RJ
See you there
Old Nov 17, 2004 | 10:45 AM
MattD@Stoptech's Avatar
Those magical wheels will steer j00 right......and left...
Old Nov 17, 2004 | 11:15 AM
mstewar's Avatar
Default Re: NASA Race Car Inspections. - Northern Virginia (El Pollo Diablo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">
haha.. they better! and the 2nd set too, once I get around to scrounging up the cash for them..
Old Nov 17, 2004 | 11:54 AM
Littleton's Avatar
Grumpy what is the name of your shop?
Old Nov 17, 2004 | 04:55 PM
Grumpy's Avatar
New User
Default Re: NASA Race Car Inspections. - Northern Virginia (Littleton)
Master Towing & Transport
BTW, my daughter lives in Ashburn. Might be able to stop by off a visit to her.
Andrie Hartanto
May 13, 2008 08:43 AM
trigun7469
18
Apr 17, 2007 05:18 PM
Honda318dx
11
Sep 13, 2005 09:10 AM
Tyson
17
Dec 7, 2004 03:52 PM
EF8VTEC
May 29, 2003 11:18 AM
