EGR control device not working
Old Nov 16, 2004 | 11:25 AM
mach2_3's Avatar
Default EGR control device not working
Hi
I have a 92 prelude 2.3 Si H23A . Recently i have had a code 12 problem which ccame out to be my EGR solenoid not working. my question is wht exactly it is and how can i replace it.
Old Nov 16, 2004 | 11:34 AM
delguiner's Avatar
Default Re: EGR control device not working (mach2_3)
basically what it does is it re-circulates unburnt fuel providing better gas mileage. You could try cleaning it (it works sometimes)
By any chance are you having some idling issues?
Old Nov 16, 2004 | 12:25 PM
mach2_3's Avatar
Default Re: EGR control device not working (delguiner)
No i dont really have any idling issues. It was found that my soleniod is bad .....can i change it my self. where do i get instructions .plz help
Old Nov 16, 2004 | 12:42 PM
delguiner's Avatar
search dude, this was covered a bunch of times... but basically all you do is you take off the EGR valve and you clean it thoroughly with carbon cleaner and try to see if it works... if it doesnt you either block it off or you buy a new egr valve!
good luck
Old Nov 16, 2004 | 01:10 PM
chitownrida's Avatar
first step is to make sure the hose connecting up to it has vacuum pressure.. (from service manual) i had same problem
ben
D-Atk
Aug 21, 2019 03:35 PM
hecubus
Feb 21, 2014 04:47 PM
darkvibe
May 28, 2013 08:01 PM
luderollin
Apr 3, 2005 10:41 AM
mtfishin
Nov 8, 2004 06:35 AM
