motor mount removal
Old Nov 16, 2004 | 10:42 AM
Ronin150's Avatar
Default motor mount removal
I'm trying to remove my motor mounts because I was a mean owner and didn't replace the front one and now I have 3 broken ones. I'm trying to remove the driver's side motor mount. I got the main pin out and the first bolt (one closest to the front) but I was wondering how do I get the rear bolt off. Does the nut unscrew that's on the top or is that welded in. TIA
Old Nov 16, 2004 | 11:26 AM
rasta420's Avatar
Default Re: motor mount removal (Ronin150)
that nut is welded on from the top...remove the bolt from the bottom. (if this is the one towards the front of car)
Old Nov 16, 2004 | 11:55 AM
Ronin150's Avatar
Default Re: motor mount removal (rasta420)
It's the one to the rear. I already got the one in the front off. Thanks for the help tho
Old Nov 16, 2004 | 07:09 PM
rasta420's Avatar
huh? you said you were trying to replace the drivers side engine mount. theres one through bolt and one bolt that threads in from the bottom, and another bolt or nut, i dont remember, but it comes off from the top. jus follow what i said.
Old Nov 17, 2004 | 02:24 AM
NCRXSi's Avatar
See if this will help Engine Removal The bolt towards the front is removed from the bottom, the nut on top at the back bolt is removed from the top.
Old Nov 17, 2004 | 09:21 AM
rasta420's Avatar
Default Re: motor mount removal (NCRXSi)
like i said..
Bob_760
May 17, 2007 10:37 PM
george34
13
Feb 22, 2006 11:09 AM
mkazm83
Jan 28, 2006 04:46 PM
DMF
Oct 13, 2003 06:25 AM
ragejed
Jul 10, 2002 04:30 PM
