What is the difference between cable and hydro tranny?
Old Dec 27, 2001 | 04:58 AM
is3oo's Avatar
Default What is the difference between cable and hydro tranny?
Old Dec 27, 2001 | 05:23 AM
eg6ajk's Avatar
Default Re: What is the difference between cable and hydro tranny? (KPxRyDa)
cable trannies came in 88-91 civic, and 90-3 integras, different mounts, mounting points, different size gears and case then compared to 92-00 civics and 94-01 integra, which uses hydro tranny,
also it is easier to use the same type of tranny (cable or hydro) your came with, otherwise, alot of work will be required....
Old Dec 27, 2001 | 05:54 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
a "cable" tranny means that the clutch is operated via a cable. a "hydro" tranny means that the clutch is operated by hydraulic pressure, similiar to the way brakes work.
Old Dec 27, 2001 | 06:40 AM
is3oo's Avatar
Default Re: What is the difference between cable and hydro tranny? (rodney)
Thank u.
Quada
Transmission & Drivetrain
Feb 2, 2010 03:27 PM
todaspec b
May 31, 2006 01:40 PM
LSpimpTEC
Jun 15, 2004 07:38 PM
