HELP, installing 99 SI dash, and gauge cluster in to 95 hatch
Old Nov 16, 2004 | 07:31 AM
speedhatch's Avatar
Default HELP, installing 99 SI dash, and gauge cluster in to 95 hatch
just like the topic says, can anyone help me out, putting the gauge cluster in is really what the problem is, the rewireing, does anyone have any diagrams? thanks in advance...
i did a search for this and i couldnt find anything usefull,
can anyone help?
Old Nov 16, 2004 | 07:45 AM
theWB's Avatar
Default Re: HELP, installing 99 SI dash, and gauge cluster in to 95 hatch (speedhatch)
speed hatch i have a dx that i had wired a 99 si cluster too there was really no diagram when i did it .. get the si cluster with the plugs cut then far enough for you to hjave room make sure you cut the stock cluster off but leave room on the old plugs so that you may one day reinstall it if not throw it out if you notice they colors on some of the color match start byt there...... EXAMPLE their are some wires that are solid colors with with a solid line in another color ans maybe one silver spec or maybe even two ...... MATCH THESE UP FIRST LOOK FOR WIRE THAT ARE SIMILAR IN COLOR THE ONES LEFT OVER connect another thing test your dash accesorie what i mean by this is have some open and close the hatch for example and run through all the wires on the cluster find the light for the hatch or trunk follow the brass map untill you see moreorless to what connector bundle it goes too now simply begin going wire by wire till the trunk light turns on , same for doors same for light , highbean etc . same for the ebrake etc.. i came to find the last wire by mistake the speedo was still not working but the seatbels light trunk brake everything was operational exept the gas gauge aswell as i was driving around the block the speedo did not work but i noticed a puls a blinking light in the gas acces. bulb on the cluster as i would accelorate i saw it blink faster and faster when i slowed it blinked slower till i came to a stop then it would not blink . so i figure this would be a speedo signal so i changed then both around and now by gas would work and the speedo work fully operational ..... if you have any question let me know
Old Nov 16, 2004 | 09:53 AM
speedhatch's Avatar
Default Re: HELP, installing 99 SI dash, and gauge cluster in to 95 hatch (theWB)
hey thanks alot man, but iam still a lil confused, is there any eaiser way to do it
Old Nov 16, 2004 | 10:28 AM
BlueIntegraBoy's Avatar
Just match the function from the 95 Civic into the 99 plugs.
https://honda-tech.com/zerothread?id=1053318
Old Nov 17, 2004 | 12:36 PM
speedhatch's Avatar
wow thanks alot guys this should def help me out
Old Nov 17, 2004 | 12:37 PM
speedhatch's Avatar
if i run into any problems or have anymore questions i'll let you guys know thanks
Old Nov 17, 2004 | 12:52 PM
pydwy213's Avatar
u dont wanna do the dash tho...cluster is enough work
Old Nov 19, 2004 | 08:39 AM
speedhatch's Avatar
Default Re: (1992GS-R)
whats the deal you dont think i should do the dash swap
Old Nov 19, 2004 | 03:00 PM
noahblkmale's Avatar
Default Re: (speedhatch)
i put a gsr cluster in my eg and didnt like how it look and put my stock back u gonna have crazy room around it, It just didint look stock like it is a a gsr u find a way too make it look good post it thanx
Old Nov 21, 2004 | 05:56 AM
daidilus's Avatar
fahsheeeeezy!!! this is exactly what i needed to install the EG cluster into my EF muah muah muah TYTYTYTYTYTYTYTYTYT!!!!
Old Nov 22, 2004 | 10:51 AM
speedhatch's Avatar
ya i hear that but iam puting the whole dash in not just the cluster
Old Nov 22, 2004 | 10:53 AM
speedhatch's Avatar
thank u HT i think i can put it in this week
Old Nov 22, 2004 | 11:35 AM
daidilus's Avatar
please lemme know..i have one i wanna install also!!
Old Nov 22, 2004 | 03:02 PM
speedhatch's Avatar
Default Re: (daidilus)
ya i will do man, i hope its not to hard
Old Nov 29, 2004 | 10:30 AM
speedhatch's Avatar
Old Dec 2, 2004 | 07:25 AM
speedhatch's Avatar
Old Dec 6, 2004 | 03:33 PM
speedhatch's Avatar
en00be
Feb 20, 2009 04:20 AM
Mr Instigate
Oct 31, 2004 05:51 PM
