where to run power and RCA wires in 92 hatchback???
Old Dec 27, 2001 | 04:07 AM
92Hatcher's Avatar
Default where to run power and RCA wires in 92 hatchback???
Where do you recommend running Power and RCA wires from firewall to amp install in tirewell? would you run power wires on either driver or passenger sides and RCA on side of middle hump?
What is best place to run 8 gage powerwire through firewall?
Old Dec 27, 2001 | 08:47 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: where to run power and RCA wires in 92 hatchback??? (92Hatcher)
Run the power cable through the firewall just to the left and down from the battery. There is a grommet there that come out behind the A/C unit in passenger footwell. Cut a small slit in the grommet with a Xacto knife. Then wipe powercable down with Armorall and slide it through. The Armorall will keep the wire from pulling the grommet through the firewall.
I ran the power down passeneger side, RCA's down the left, speaker leads BACK to the front up through the middle.
MilanoCivic97
Audio / Security / Video
Apr 14, 2007 05:22 PM
TurboTeG4
Jul 19, 2003 11:42 AM
Skitals
Feb 27, 2003 11:20 AM
Volcom
Dec 30, 2001 11:49 AM
