Can I safely bore to 84mm?? (ls block)
Old Nov 16, 2004 | 06:51 AM
awdriscol4's Avatar
Default Can I safely bore to 84mm?? (ls block)
Whats the most you can bore a ls block to safely in its stock config?? I will be using a block gaurd, but dont want to have to go into sleeving....can I get 84mm?? Anyone have any experiences with it?
Thanks
Alfred
Old Nov 16, 2004 | 09:24 AM
gsrboi80's Avatar
Default Re: Can I safely bore to 84mm?? (awdriscol4)
I think thats too much. somone else back me up
Old Nov 16, 2004 | 09:50 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: Can I safely bore to 84mm?? (gsrboi80)
Not even close!
Honda recommends as a MAXIMUM to bore 20 over or 0.020 over (same thing). This will give you a bore size of 81.5mm. This is only for purposes of repair on the cylinder wall, NOT for any performance gain.
If you want/need to go any more, you will need to get aftermarket ductile iron sleeves. In that case, most will allow you to go to 84mm as a maximum on a B18 block.
deltahotel22
19
Mar 19, 2012 08:52 PM
No
May 1, 2005 06:45 AM
EgSick
May 15, 2003 09:29 AM
USDMMARK
Feb 9, 2003 01:58 AM
