official camshaft review thread
everyone has different opinions on camshafts. so how bout getting all of the opinions togethor.
camshaft: brand of camshaft
where you bought it: name the store or private party if you bought it through private party.
cost: cost of it
quality: scale of 1-10
1-****
10-awesome
durations:
car setup:
cost: cost of it
1-****
10-awesome
durations:
car setup:
SOHC CROWER STAGE 3.
10
somewhere in the neighborhood of $300
eh you guys can search for cam specs.
Idles fine, not too wild at all.
Setup: Supertech valve train on stage 3 cams, 11.5ish:1 compression.
10
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Br1anPham »</TD></TR><TR><TD CLASS="quote">SOHC CROWER STAGE 3.
10
Setup: Supertech valve train on stage 3 cams, 11.5ish:1 compression.</TD></TR></TABLE>
wow, stage 3 crowers
. Thats the full race cam correct? don't you mean they don't idle toooo wild as in they come close to shaking your mirrors off
, lol, j/k. really, how bad is the idle? like scale on 1-10, 1 being stock and 10 being unbearable. also, that can't be your whole setup, with stage 3 cams.....is it...?
10
ZEX 59300/Comp Cams
Quality 10
dont know the durations of hand
loud valvetrain lol idle is slightly higher around 800
Stock valvetrain-rest is in my sig
Cost-200
edit:
power gains-Felt it quite a bit on the butt dyno
Modified by Soccerking3000 at 9:20 PM 11/16/2004
Quality 10
Cost-200
edit:
The best time ran with this motor was a 12.40@ 108 MPH with a 1.86 60 ft in a eg wieghing 2100 lbs.
B18c5 2000 type R block
Civic type R pistons with stock ITR crank and Rods
Nuforms blockgaurd, total seal piston rings
B16a head port & polished with 3 angle valve job by Portflow
Skunk2 valvesprings and retainers
ITR lost motion (lifters), ITR rocker arms
Fierra valves, Bronze valve guilds, ARP head bolts
Skunk2 stage 2 cams with A.E.M adjustable sprockets
Skunk2 port-matched manifold with ITR throttle body
RED ITR valve cover
2000 JDM ITR tranny (4.7 final) No Grinds in perfect condition
Toda Light weight flywheel
A.C.T pressure plate with street/strip clucth
Two headers to chose from:
Custom header made by MIDNIGHT PERFORMANCE
A.E.M fuel rail with A.E.M fuel regulator
R C 440cc injectors
P28 with Hondata S200 Dyno tuned to motor by MIDNIGHT PERFORMANCE
RED ITR valve cover
R C 440cc injectors
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egSIboi »</TD></TR><TR><TD CLASS="quote">back from the dead, muahahahaha
anyone have some experiences with skunk2 or crower stage 2's?</TD></TR></TABLE>
crower stage 2 for z6
no wear whatsoever after one year of use
Crower 62402T-2 - ACURA 1.8 RS/LS DOHC TURBO CAMSHAFT
Purchased from Crower
$400 for the pair
quality: 10-awesome
durations: 235 / 235
car setup: Turbo B18B, stock bottom end, pnp head with crower cams, springs, and retainers
These cams help my motor make 20whp per pound of boost. Dyno proven.
$400 for the pair
quality: 10-awesome
Cam: Skunk2 Stage 1 for SOHC
Bought from: BlackEG
Cost: $220 shipped ($435 brand new)
Quality: 10
Specs:
IN. 0.470, 240;
EX. 0.445, 240
Setup:
RedZone Performance Chipped P28 Program, Custom 2.75" Intake, 4-1 Header, testpipe, JDM ITR B-Pipe, Custom Mugen Style axle back
Comments:
Overall it's a great cam...got some nice valvetrain noice. I found that my 2.75" Intake pipe yielded better gains topend than my 2.5", also made the vtec engagement a whole lot louder. From what I can tell...the cam makes power to about 7500 roughly...and I'm revin it up to about 7700 with my program. The extended powerband on this cam helps out when racing B-Series cars that are revin that high or higher. To date...I've raced and beat a GSR w/ Full bolt-ons and chipped ECU, and GSR Swapped EK w/ I/H/E, and a B20/Vtec Integ w/ intake, skunk2 stage 1's, AEBS manifold, being the fastest three. I've been told that everyone in the areas I've raced think I have a B16 or GSR swap.
One complaint have that I noticed...when I cold start the car...the engine doesn't start up like it used to...it's slowly increases in RPM's. Don't know if it's the cam or my engine is old(190k miles).
Quality: 10
Specs:
IN. 0.470, 240;
EX. 0.445, 240
Setup:
Comments:
nick, sounds like that cam is treating you very well
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tony Starks »</TD></TR><TR><TD CLASS="quote">Crower 62402T-2 - ACURA 1.8 RS/LS DOHC TURBO CAMSHAFT
$400 for the pair
quality: 10-awesome
ok now thats badass! i want the 402T's for my ls turbo, but i guess i gotta turbo the ls motor first
. i hear many good things about the crower non vtec cams
.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tony Starks »</TD></TR><TR><TD CLASS="quote">Crower 62402T-2 - ACURA 1.8 RS/LS DOHC TURBO CAMSHAFT
$400 for the pair
quality: 10-awesome
