Check your gas lines!!!!!
Old Nov 16, 2004 | 05:18 AM
EFz6er's Avatar
Default Check your gas lines!!!!!
So Im driving down the road on my way home from work and some guy in a hatch pulls up on the side of me and tells me Im leaking gas bad. I pull into the closest gas station and look and its pissing out. I traced the gas lines under the rear seat and of the 3 lines the one that is closest to the middle of the car that is loose. Is that the return line?
The car still runs so its getting gas. I wasted a 1/2 tank in 25 miles.....this **** sucks.
Old Nov 16, 2004 | 08:15 AM
EFz6er's Avatar
Default Re: Check your gas lines!!!!! (EFz6er)
I need to ID this gas line....Im damn sure its the return line beause the car runs fine. Again its the one closest to the middle of the car.
Old Nov 16, 2004 | 08:27 AM
sullenht's Avatar
I do think that is the return line it should be located off the back of the engine
Old Nov 16, 2004 | 09:02 AM
EFz6er's Avatar
Default Re: Check your gas lines!!!!! (sullenht)
Thanks
spooledhonda
Sep 16, 2007 07:11 PM
efyou
37
Feb 8, 2006 08:07 PM
R you serious
Aug 18, 2003 05:26 PM
