clutch ???????? please help
ok here is what happend
i drove in rain not too too bad then i got home and when i pulled in to the driveway in first gear i noticed the car was shaking but i ignored thinking the motor just got wet it ill dry well the next day i started the car and it wont go in gear when car is on but will go in gear when car is off so far i drained the tranny to look for water but none what else could it be before i take tranny off also if it where the clutch master cylinder leak would the resevoir be empty and does any one have a pic of a clutch master cylinder or slave cylider
thanks a lot in advance
to answer the only part of the question that I can,
Yes, the reservoir would be empty. The master or slave just need to be replaced. Cheap parts, and you could probably put it in yourself.
lo0nY
Feb 26, 2006 03:58 PM
