idle fluctuates. when stopped very low- sometimes stalls. Any ideas?
Old Nov 15, 2004 | 11:39 PM
civic-lsi-vtec's Avatar
Default idle fluctuates. when stopped very low- sometimes stalls. Any ideas?
civic lsi vtec 1996 3 door hatchback.
since ive had the head gasket replaced idle fluctuates between 1000 -200.
When i come to a stop idles low and sometime stalls. Stalling increases if a put my foot down. Things ive done are:
throttle body cleaned
sparkys changed
ecu reset
air intake screw adjusted
vacuum pipes checked
Sometimes the car feels really rough and other times ok whilst idling. Usually happens when engine is warm. No engine light..
is this technical or what
Old Nov 17, 2004 | 01:05 PM
thelucysong's Avatar
Default Re: idle fluctuates. when stopped very low- sometimes stalls. Any ideas? (civic-lsi-vtec)
I have the same problem.
Old Dec 16, 2004 | 09:02 PM
DVS Luder's Avatar
Default Re: idle fluctuates. when stopped very low- sometimes stalls. Any ideas? (thelucysong)
I got the same problem and it is getting annoying. It comes and goes tho. It'll drive fine for a week or so then out of nowhere my idle fluctuates and it stalls..then I lose power steering and all that, plus it makes me look like I stalled.
Old Dec 16, 2004 | 09:04 PM
DAguyLS's Avatar
this is already being discussed on here right now
Idle Air Control Valve........do yourselves a favor and try hitting the button at the top right of your screen that says "SEARCH"
Old Dec 16, 2004 | 09:14 PM
OTI-'s Avatar
I have an aftermarket OBX intake maifold (please dont flame i know its garbage it came with the car) and my car idles up and down but only in park its weird and annoying will get my swap soon thats the only reason i havnt put a oem maifold on it.
Old Dec 16, 2004 | 11:40 PM
texasnick's Avatar
IACV baby!!!
you probably don't even need it replaced. Check it, and clean it
The low rpms while stopped though sounds like it might be a sealing problem with your gaskets. I would check those too
GL with that, **** happened to me a while back and the fluctuating idle is sooooo damn annoying
Old Dec 18, 2004 | 09:34 AM
Default Re: idle fluctuates. when stopped very low- sometimes stalls. Any ideas? (texasnick)
check this out my old thread. Could be the same problem!!
https://honda-tech.com/zerothread?id=1057877
joelmatt89
15
Nov 4, 2009 05:27 PM
lilCivic
Feb 2, 2005 05:36 PM
civic-lsi-vtec
16
Dec 24, 2004 05:26 AM
walsredprelude
Oct 30, 2004 09:42 AM
