question on b18c1 head
Old Nov 15, 2004 | 11:34 PM
lv6l's Avatar
Default question on b18c1 head
i am removing a gsr head and i have taken off all 10 long bolt from the head, i want to know is there any other bolts that is preventing the head from coming off its block. i've taken off the headers, cam shafts, cam gears, distributor. thanks.
Old Nov 15, 2004 | 11:36 PM
Sack Master's Avatar
Default Re: question on b18c1 head (lv6l)
Well there are only those bolts. But more than likely you are snagging on a water hose or sensor plug or something along those lines. Maybe the intake manifold support bracket or something. Of course those dowel pins make it a really tight fit and providing everything is off that may be your only issue.
Old Nov 16, 2004 | 05:05 PM
lv6l's Avatar
oh thanks yeah, the head is wanted to come off if you lift it up, but it does seem like somthing is holding the intake manifold down on the left side of the manifold, how many support bracket are there under the manifold?
Old Nov 16, 2004 | 07:57 PM
mr.beeks's Avatar
Default Re: (lv6l)
there is only one bracket
holding the manifold
yohimbine
Jul 31, 2013 04:45 PM
gsrkid24
Dec 21, 2009 02:49 PM
kadidle
Jan 12, 2008 02:23 PM
mixmastermatt
Apr 19, 2007 05:42 AM
HaUTSaauce
Mar 22, 2003 07:06 PM
