do they make aftermarket roller rockers for B-series?
I am looking to make a jam up N/A engine and I am wanting to free up power anywhere I can, and this includes cam friction. If anybody knows of roller rockers that are sold for a B-series...please point me in the right direction and I will be on my merry way.
would these rockers allow use of the stock cam im boosting so i dont need any crazy all motor cam,if the gsr cams work that would be nice, but do I buy a vtec cam with a turbo profile,will these cams still work? And also is there any other parts replaced in the valvetrain when you do this?Would you need the vtec solenoid for oil suplly to the head,or can you completly remove it and not starve the head of oil???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC_DC4 »</TD></TR><TR><TD CLASS="quote">Yes </TD></TR></TABLE>
As others have already stated the correct answer is no.
I have seen about 4 different sets of aftermarket rockers including some that utilize the stock middle rocker but non of witch operate on primary and secondary lobes. I have not seen a set yet that does not lock the three rockers together to essentially eliminate vtec.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxVtecC1 »</TD></TR><TR><TD CLASS="quote">would these rockers allow use of the stock cam </TD></TR></TABLE>
Some do but the Crane rockers do not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKhatch »</TD></TR><TR><TD CLASS="quote">
let me geuss you can only use crane cams too?!
So is there a different cam for other than crane rockers to eliminate vtec?Has anyone used the crane rocker follower/cam setup if so what do you think? and also is there a good turbo profile cam for this setup other than crane cams? anyone?............
</TD></TR></TABLE>let me geuss you can only use crane cams too?!
1slowcrx
Jun 12, 2004 11:27 AM
