The R has sustained some damage
Old Nov 15, 2004 | 11:14 PM
dandc2's Avatar
Default The R has sustained some damage
well... unfortunately tonight, I sent the itr right into a curb and pretty hard....
i just got a pair of puma speedcats the other day... and on my way home i figured i'd test them out a bit in an empty mall parking lot. What i didn't notice is that the sprinklers had wet some of the surrouding area. Push comes to shove and azenis under heavy breaking in the wet = not good idea.... and the car slid into a curb
it happened to the front driver side wheel, and the entire thing seems to be pushed back a bit, slightly rubbing against the wheel well
also the car looks lowered on that driver side front, I am thinking its a broken axel but I'm not sure, its 3 am so I can't really get a good look at it
whatever it is hopefully it isn't to expensive cause im broke right now
oh and to all the haters.... flame away
Old Nov 15, 2004 | 11:15 PM
top fuel's Avatar
Old Nov 15, 2004 | 11:17 PM
dandc2's Avatar
Default Re: (top fuel)
HAHAHA nice
Old Nov 15, 2004 | 11:19 PM
B2FiNiTY's Avatar
That is pretty darn hilarious!
Old Nov 15, 2004 | 11:22 PM
rough_draft's Avatar
ty ty, i'm proud to say that is me
Old Nov 15, 2004 | 11:29 PM
B18OnTop's Avatar
Default Re: (rough_draft)
Old Nov 15, 2004 | 11:30 PM
dandc2's Avatar
Default Re: (B18OnTop)
does anyone have any input as to what it might be??
ill get a better look at it tomorrow... and maybe post some pics if i can get my hands on a digicam
Old Nov 15, 2004 | 11:48 PM
00R101's Avatar
Default Re: (dandc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dandc2 &raquo;</TD></TR><TR><TD CLASS="quote">does anyone have any input as to what it might be??
Let's see....could it be....yes, it is...
The judges all agree:
Bad decision, street racing in uncontrolled environment = damaged car.
Next time, try out your driving shoes at an autocross!
Old Nov 15, 2004 | 11:55 PM
dandc2's Avatar
Default Re: (00R101)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00R101 &raquo;</TD></TR><TR><TD CLASS="quote">
Next time, try out your driving shoes at an autocross!</TD></TR></TABLE>
well for starters I wasn't street racing, there was no on else involved
i just took a corner hard and didn't notice that it was a wet corner... any helpful info would be appreciated
Old Nov 16, 2004 | 02:59 AM
dsisive407's Avatar
From: around the corner to the left ... no, your other left
sad to hear about the R man .. sucks .. stop trying to race mall rats man .. j/k .. on a better note im keepin the R
Old Nov 16, 2004 | 04:56 AM
Bbasso's Avatar
Default Re: The R has sustained some damage (dandc2)
Having fun =
slamming a curb =
walking away = priceless
I would think you bent the suspension, possible the lower arm, tweaked a bushing and possible the mounting point on the frame.
Make sure that you find out 100% before you make it road worthy by getting a wheel alignment.
good luck on the repair.
Old Nov 16, 2004 | 04:59 AM
Jon D's Avatar
Default Re: The R has sustained some damage (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">
good luck on the repair.</TD></TR></TABLE>
Old Nov 16, 2004 | 05:11 AM
ericlee303's Avatar
Default Re: The R has sustained some damage (B18C-Rsi)
Also check that you didn't bend the rim. It might be bent along the axis, which is much harder to fix than a bent lip.
Good luck, and glad you didn't dent yourself.
Old Nov 16, 2004 | 06:07 AM
Dave_B's Avatar
Damn dan what did you do??? Give me a holler if you need help in the repair.
Old Nov 16, 2004 | 06:13 AM
1GreyTeg's Avatar
First with the car on the ground grab the wheel/tire and try to move it shake it.
Then jack it up and see what kind of play there is.
Then pull the wheel off and check to see what else could be damaged.
Check the entire wheel and tire to see if it is something simple like a bent wheel.
And above all Take pics of all of this and post it up if you want any sort of real help or more suggestions. In short, if you don't know what to look for or at, a good idea would be to take it to a professional.
FYI Azenis had nothing to do with your loss of control, your cars damage was completely driver error and poor judgement. If you didn't want people to comment on your actions, then don't post them up.
Don't forget, you asked to be flamed and then they obliged.
Old Nov 16, 2004 | 07:15 AM
jaa1311's Avatar
around about a year ago i hit a patch of ice and went into a curb suffering the same problem you are. I ended up comming away w/ a bent rota and lower control arm. Depending where you look the lca will run you anywhere from $100-$200 and they are not to much of a hassel to put on. Hope that helps
Old Nov 16, 2004 | 07:32 AM
extrah's Avatar
Default Re: The R has sustained some damage (jaa1311)
Get some pics up so we can see teh damage.
Good luck on the repair anyways.
Old Nov 16, 2004 | 07:47 AM
nightrider's Avatar
that's pretty funny. it's almost as funny as when skafia got some dorifto action in his new s2k.
Old Nov 16, 2004 | 08:37 AM
toEknEEg's Avatar
Default Re: The R has sustained some damage (nightrider)
dont worry danny.. ill be over there in a few hours.. the jamlando krew got your back bro
my first guess will be your lower control arm, and (i forgot the name) the bar that adjusts your toe..
watever it is.. we will fix it.
Old Nov 16, 2004 | 08:43 AM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: The R has sustained some damage (toEknEEg)
wtf dan? Bring it over so I can laugh at you
Let me know if you need some help or towing with the X
Old Nov 16, 2004 | 09:09 AM
Opie's Avatar
Old Nov 16, 2004 | 09:27 AM
dandc2's Avatar
Default Re: The R has sustained some damage (1GreyTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">First with the car on the ground grab the wheel/tire and try to move it shake it.
Don't forget, you asked to be flamed and then they obliged.</TD></TR></TABLE>
i agree 100%... i know it was my fault and im ok with people flaming... after all this is the infamous HT ITR forum.... where the worst flamers on the net reside
Old Nov 16, 2004 | 09:36 AM
mikestypeRR's Avatar
ill get a better look at it tomorrow... and maybe post some pics if i can get my hands on a digicam</TD></TR></TABLE>
dan what the hell were you thinking man! lol
anyways listen when i had my gsr... i slide it into a curb as well... the wheel was bent back just like you descrbed... I ended up bending
1. The spindle
2.uppeR control arm
3.loweR control arm'
hope this helps...
I found the parts are a local junk yard... but for our "R's" I dont think you will find those there
should be a hefty repair bill
hope you learned your lesson, curbs are meant to be driven over by a mudd truck.
by the way... if you bent your wheel call me... i have the number to that company that fixed the wheels on my first R. "they did a unbelivable job"
Old Nov 16, 2004 | 11:24 AM
dandc2's Avatar
Default Re: (mikestypeRR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikestypeRR &raquo;</TD></TR><TR><TD CLASS="quote">
1. The spindle
2.uppeR control arm
hope this helps...
by the way... if you bent your wheel call me... i have the number to that company that fixed the wheels on my first R. "they did a unbelivable job" </TD></TR></TABLE>
actually i called acura... and the front lower control arms are the same for all the integras....and a buddy of mine has a spare one layin around so im pretty lucky... cause acura told me they cost $301 per lower control arm
so far it looks like thats the only problem... the upper control arm doesn't look bent.... tony is coming over though to take a look at it
Old Nov 16, 2004 | 03:21 PM
Mythias's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikestypeRR &raquo;</TD></TR><TR><TD CLASS="quote">anyways listen when i had my gsr... i slide it into a curb as well... the wheel was bent back just like you descrbed... I ended up bending
1. The spindle
2.uppeR control arm
I did the same damn thing once before.. slid on ice going around a turn, just kept going more or less straight, and BAM. Mine was a bit worse though, since the wheel actually made it all the way up into the fender, crumpleing the finder into both the door and hood... not to mention a badly bent rim. I never want to experience that again.
