CAR PROBLEM NEED HELP.
Old Nov 15, 2004 | 10:26 PM
alpha_1's Avatar
Default CAR PROBLEM NEED HELP.
all i want to know is why does my car choke when the car is warmed up. like when step on gas the car will go but all of a sudden it chokes. i feels like its not going and its going to die then all of a sudden it picks back up again. i can't seem to figure out what is the problem. if anyone has had this problem please tell me so i could fix my car. it also feels like its studdering.
also my head gasket that i have used for 3 weeks now has been leaking oil from where the head meets the block. i was wonder if i could re-use the same head gasket. its only been on the motor for about 3 weeks.
Old Nov 21, 2004 | 09:35 PM
alpha_1's Avatar
Default Re: CAR PROBLEM NEED HELP. (alpha_1)
bumb......anyone with an ideai on how to fix this problem?
Old Nov 22, 2004 | 08:59 AM
tblazak's Avatar
about your car "chocking" and "stuttering", can you be a little more specific. Like does it happen at a certain rpm, what does it do exactly...
Old Nov 22, 2004 | 12:25 PM
incredteg3's Avatar
Default Re: CAR PROBLEM NEED HELP. (tblazak)
sounds like ignition to me
Old Nov 22, 2004 | 01:10 PM
IO_303's Avatar
not enough of something....
air
fuel
air: get a bigger intake pipe
fuel: fpr <-worked for me
Old Nov 22, 2004 | 01:48 PM
sammysnakes's Avatar
check your ignition timing.
Old Nov 25, 2004 | 10:44 PM
alpha_1's Avatar
ok it starts "chocking" or "studdering" like around 2 to 3000 rpm. then after that it picks up. it only happens when the car is warmed up. also i went to buy a MSD external coil and the problem is still happening.
Old Nov 27, 2004 | 09:14 AM
tblazak's Avatar
I've had a similar problem but it was happening at around 4k on a vtec motor. Turns out there was moisture that was trappen in the spark plug boot (all of that crazy rain) Try driving your car around then removing the spark plug wires over night to let the dry out.
Its worth a shot.
good luck
Old Nov 28, 2004 | 12:22 AM
alpha_1's Avatar
well i took the head to a machine shop to do a vaccum test or bent valves and they say that one of my intake valve seems like it has little vaccum. they say that could cause the car to mis-fire sometimes. can that be the cause or is there some thing else?
Old Nov 28, 2004 | 08:18 PM
dfoxengr's Avatar
crappy fuel filters also cause bogging.
FSU-pike4lyf
Honda Civic (2001 - 2005)
Oct 12, 2013 08:44 PM
Atomic_EF9
May 8, 2010 03:50 PM
speedking
Jun 29, 2008 09:22 PM
SIINSI
Jan 16, 2004 07:08 AM
CHRIS 1.8
19
Mar 11, 2002 09:27 AM
