squeaky clutch
Old Nov 15, 2004 | 08:26 PM
mrcheapyasui's Avatar
Default squeaky clutch
i have a 97 gsr and ive been noticing my clutch squeaks when i put it in and out recently. Is this somthing bad or what?
thanks
Old Nov 15, 2004 | 08:35 PM
SiR Inspired ED7's Avatar
Default Re: squeaky clutch (mrcheapyasui)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrcheapyasui &raquo;</TD></TR><TR><TD CLASS="quote">i have a 97 gsr and ive been noticing my clutch squeaks when i put it in and out recently. Is this somthing bad or what?
thanks</TD></TR></TABLE>
i have a 93 teg mine squeaks a tiny bit...i think it's normal...
i have no problems...
Old Nov 15, 2004 | 08:42 PM
WhiteGSR95's Avatar
i have the same problem but it squeels kinda loud.
Old Nov 16, 2004 | 05:30 AM
JimBlake's Avatar
Default Re: (WhiteGSR95)
Grease the ball & socket where the slave cylinder pushes against the throw-out fork. Maybe you can get some grease into the t-o-fork pivot? Maybe a little grease inside the slave piston boot?
Old Nov 16, 2004 | 05:58 AM
HONDA RR's Avatar
Default Re: (JimBlake)
Its probably you clutch release bearing or throw out bearing.
Old Nov 16, 2004 | 07:36 AM
simon98h22's Avatar
Default Re: (MITSUBA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MITSUBA &raquo;</TD></TR><TR><TD CLASS="quote">Its probably you clutch release bearing or throw out bearing.</TD></TR></TABLE>
Does it squeak when not depressed or when you depress it/release it?
Old Nov 16, 2004 | 07:49 AM
95 integra's Avatar
Default Re: (simon98h22)
Ive pretty much replaced my entire clutch system(fluid, clutch master cylinder, slave cylinder, clutch, bearing, greased fork, lubed pedal, etc) and mine still squeaks some days.....
pli
Sep 1, 2006 04:09 PM
Felt.2
Aug 13, 2006 03:47 PM
pr0phet
Nov 12, 2005 03:15 PM
FD3S
May 1, 2004 12:33 AM
AspectIndustries
Jan 5, 2004 07:49 AM
