Front LCA/Knuckle/Bearing Replacement Cost Check
Old Nov 15, 2004 | 07:23 PM
propulsion1's Avatar
Default Front LCA/Knuckle/Bearing & T-Belt-Water pump Replacement Cost
My new mechanic quoted me $600 total (parts and labor) to replace my Front left LCA/Knuckle/Bearing; but would not tell me what the breakdown of parts/labor cost is. He said this does not include the hub, assuming that it is still usable.
I have no clue if this is correct or reasonable. I know the bearing costs about $50+, but no idea what the LCA or Knuckle costs.He said that the bearings will be unusable after removed from the knuckle, and that I should also re-align my car after that.
He also quoted 700+ for timing belt and water pump replacement (parst & Labor). IS that reasonable?
Any inputs? I need to tell him by tmrw as he needs to order parts. Thanks.
Old Nov 15, 2004 | 08:13 PM
Default Re: Front LCA/Knuckle/Bearing & T-Belt-Water pump Replacement Cost (propulsion1)
Any suggestions? Or if anyone can provide a rough breakdown of the part prices.
He said this will take roughly 4 hrs of labor.
Thanks.
Old Nov 15, 2004 | 09:36 PM
Mugen Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by propulsion1 &raquo;</TD></TR><TR><TD CLASS="quote">My new mechanic quoted me $600 total (parts and labor) to replace my Front left LCA/Knuckle/Bearing; but would not tell me what the breakdown of parts/labor cost is...........Any inputs?</TD></TR></TABLE>
Tell him to screw himself. Any honest mechanic will give you a breakdown on cost of parts & labor.
You should be able to find a cost on parts here: http://www.acuraautomotivepart...cgry5=
Old Nov 15, 2004 | 09:46 PM
baonest's Avatar
Default Re: Front LCA/Knuckle/Bearing & T-Belt-Water pump Replacement Cost (Mugen Mike)
you should be able to work on these parts yourself. save $$
Old Nov 16, 2004 | 04:59 AM
Default Re: Front LCA/Knuckle/Bearing & T-Belt-Water pump Replacement Cost (baonest)
Thanks for the reply. I cannot find the price of the knuckle or LCA. I think the knuckle is listed as 200+, and the LCA as 50+ but cannot confirm. I woudl work on it myslef, but it is getting cold here. Thanks.
Old Nov 16, 2004 | 05:30 AM
Bbasso's Avatar
WOAH those prices are being robbed without a gun, look else where!
where are you maybe someone on here could help you out or recommend a place near you.
Old Nov 16, 2004 | 06:07 AM
JeffS's Avatar
LCA - $250 retail
knuckle - $250 retail
bearing - $60 retail
$560 retail
So... how are you guys coming to the conclusion that he's getting screwed?
Old Nov 16, 2004 | 06:11 AM
Bbasso's Avatar
Default Re: Front LCA/Knuckle/Bearing & T-Belt-Water pump Replacement Cost (JeffS)
Sorry I was refering to "He also quoted 700+ for timing belt and water pump replacement (parts & Labor). IS that reasonable?"
should have been clear.
Old Nov 16, 2004 | 06:18 AM
JeffS's Avatar
Default Re: Front LCA/Knuckle/Bearing & T-Belt-Water pump Replacement Cost (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">Sorry I was refering to "He also quoted 700+ for timing belt and water pump replacement (parts & Labor). IS that reasonable?"
That IS insane. There seemed to be several people saying the knuckle/lca replacement was high.
The thing is... these parts, especially the lca can be bought for next to nothing used. I'd just want to know that I was, in fact, getting new parts if I was spending that kind of money.
raverx3m
Nov 4, 2014 03:43 PM
Willz
Mar 26, 2007 07:05 PM
Larkin W.
Feb 3, 2007 02:02 PM
elnoyl
Jun 9, 2003 03:23 PM
shortyz
Jan 8, 2003 04:04 PM
