is my car goona run right with s2s1
Old Nov 15, 2004 | 07:08 PM
typesguy's Avatar
Default is my car goona run right with s2s1
i got a 99 gsr with
-cai
-dc 4-1 header
-high flow cat
-2.5in exhaust
-exedy clutch /flywheel
-s2s1
im goona put some skunk2 stage 1's in my car is it goona run right on stock fuel pressure and timing or am I gonna need like a fpr or vafc or somthing. any help would be appreciated.
Old Nov 16, 2004 | 06:34 AM
typesguy's Avatar
Default Re: is my car goona run right with s2s1 (jaydmdc2)
bump
Old Nov 16, 2004 | 08:20 AM
IN VTEC's Avatar
It'll lean out a bit. You should use whatever combination of adjustable regulator, slightly larger injectors, chipped ECU, and/or VAFC to optimize fuel. The VAFC will also allow you to optimize the VTEC crossover point since it will need to be moved up.
Old Nov 16, 2004 | 01:14 PM
typesguy's Avatar
aprecciate the help man, thanks
97Preludeguy
May 20, 2010 06:06 PM
typesguy
Dec 2, 2004 06:40 AM
b20turbojason
Aug 7, 2004 04:58 PM
Onesickcrx
May 23, 2003 09:25 PM
