Help "ITR lip on" 92-93 DA's owners
Old Nov 15, 2004 | 07:07 PM
JDMkidGSR's Avatar
Default Help "ITR lip on" 92-93 DA's owners
You DA owers that purchased the itr front lip, just one quick question. Did you guys have trouble bolting on the lip on the bumper, cuz i had to make the holes bigger, then one side of the lip is off from one side, oh and on the ends how did you guys bolt it up together, cuz mine hangs loose. Only like the front and the one on the curves have screws but not on the ends, um wut do i do. Thanks in advance.
(NOTE: This thing may sound a bit confusing - Sorry)
Old Nov 15, 2004 | 07:24 PM
importdude2000's Avatar
start bolting the lip up from the middle out
get another person to help
have one push in while the other screws it in
shoot a screw from inner wheel well.....
Newman's Avatar
New User
Default Re: Help "ITR lip on" 92-93 DA's owners (92bluteg_ls)
Here's a tip that I always have to tell people since they get over zealous and just want to throw it on w/out installing it properly. First, remove the bumper to make things a lot easier or jack the up high enough so you have room under the car. Start from the middle and work your way outward, alternating each side so you don't do all one side and then all the other. Just start the bolts, do NOT tighten them down or you won't be able to get anything to line up right. Once you have everything started, begin tightening the bolts down from the middle out, alternating sides again. That way you can align the front lip properly with the bumper. Use a tapping screw for the end into the bottom of the bumper. Then you're done.
Old Nov 15, 2004 | 07:30 PM
JDMkidGSR's Avatar
Gee Thanks you guys, ill probably do this tomorrow. Hopefully.
Samuels
May 11, 2008 11:28 AM
sittingonROTAS
Sep 17, 2005 07:11 PM
B_CRUZ!
May 8, 2005 08:43 PM
bumsta217
Oct 23, 2004 10:49 PM
integranator
Dec 9, 2002 06:47 AM
