New clutch too smooth?
Old Nov 15, 2004 | 06:52 PM
fab's Avatar
fab
Default New clutch too smooth?
The other day I got my short block changed and the dealer said that they verified that my clutch had really a loose spring so they had to change the clutch and resurface the flywheel.
Now my clutch is changed but it seems too smooth and slow (very light pressure on the clutch pedal compared to my previous clutch). It looks to me like I can not shift as fast as I used to before...Does someone can explain if I am completely nuts or else?
Old Nov 15, 2004 | 07:41 PM
accord-lude's Avatar
Default Re: New clutch too smooth? (fab)
try to bleed your clutch fluid, everytime you change the clutch you need to bleed the fluid out. there might be some air trap in there. see if that help.
Old Nov 16, 2004 | 06:10 PM
fab's Avatar
fab
Default Re: New clutch too smooth? (accord-lude)
how do I bleed the clutch fluid?
Leslie.
May 5, 2017 09:09 PM
Simple
May 15, 2004 12:17 PM
Buckshot
Nov 17, 2002 08:43 PM
VTEConly
Apr 28, 2002 03:11 AM
