help...no clutch pressure??
Old Nov 15, 2004 | 06:32 PM
ls-r civic's Avatar
Default help...no clutch pressure??
Alright so i am driving on the road and my clutch is slowing starting engage closer and closer to the floor. I drive it like this not thinkin much until i drive it for a while one day and its hard to get it in gear, by the time i get it home, the clutch has lost all pressure and i check the resevoir and it is empty. I know this is a simple question but if someone could give me the proper procedure on fixing this that would be great.
Old Nov 15, 2004 | 07:34 PM
LSVtecEK1's Avatar
Default Re: help...no clutch pressure?? (ls-r civic)
fill up the resorvoir, and pump the clutch as if you were bleeding the brakes, have someone open the slave cyclinder with a 8 mm wrench and just keep pumping and bleeding until it builds pressure. If the problem continues, its time to change the slave cyclinder.
Old Nov 15, 2004 | 07:36 PM
Downs's Avatar
Default Re: help...no clutch pressure?? (LSVtecEK1)
Definately check the MC. But I don't know about it going out that quick. Mine didn't.
ohsojdmdc
Jul 30, 2014 08:37 AM
civic=goodgasmileage
Honda Civic (2001 - 2005)
Jun 3, 2009 02:33 PM
HiAssHell
Nov 5, 2005 05:04 PM
matt2001teg
Aug 26, 2003 09:49 PM
