Fog in my LIGHTS!!!!
Old Nov 15, 2004 | 05:40 PM
95_ EG CIVIC_95's Avatar
Default Fog in my LIGHTS!!!!
I bought angel eyes a while ago and the right light has fog in it. Do you know how i can get rid of that without taking the whole lens off?
Old Nov 15, 2004 | 05:42 PM
SOHC4life 96's Avatar
Default Re: Fog in my LIGHTS!!!! (95_ EG CIVIC_95)
Get new headlights. OEM ones.
What kind of "fog" is it? Is it moisture or does the lense have a yellowish tint to them? Pictures would help out.
Old Nov 15, 2004 | 05:43 PM
pdiggitydogg's Avatar
bake them for awhile at just over 200 for a few mins or stand there w/ a hair dryer forever. If theyre anything other than total pieces of ****, there should be evap/draining holes just for this reason.
Either way, you should reseal them w/ a bead of silicone sealant all the way around the lens. If you dont, you'll always have this problem.
Big tip: get rid of those things and go back to oem's that dont do this
Old Nov 15, 2004 | 05:45 PM
iBear's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHC4life &raquo;</TD></TR><TR><TD CLASS="quote">Get new headlights. OEM ones.
What kind of "fog" is it? Is it moisture or does the lense have a yellowish tint to them? Pictures would help out. </TD></TR></TABLE>
Yes, go back to OEM headlights.
Old Nov 15, 2004 | 06:40 PM
EKKID's Avatar
I HAD THE SAME THING HAPPEN IN MY SI.
Old Nov 15, 2004 | 06:46 PM
94_HATCH's Avatar
Default Re: Fog in my LIGHTS!!!! (DOHC4life)
If its moisture they probably have a crack somewhere or some part of the plastic cover that goes over the headlight assembly isnt sealed and allowing moisture in.
Old Nov 15, 2004 | 07:18 PM
CooBlueDAB's Avatar
Default Re: Fog in my LIGHTS!!!! (94_HATCH)
ok OEM lights here, but I blew out some bulbs a while back, I think the store I got mishandled them, because they were taking them out to show people when I cam back for refund...
ANYWAYS...
There are still bulb peices in there, and once in a while, there is condensation on the inside of the lense.
How do I get all of that out?
Old Nov 15, 2004 | 07:47 PM
Default Re: Fog in my LIGHTS!!!! (CooBlueDAB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CooBlueDAB &raquo;</TD></TR><TR><TD CLASS="quote">ANYWAYS...
You are going to need to bake your head light(s) and then reseal them. And if you want the look, you can kill 2 birds with one stone and paint the housings black(I'm assuming you have an ek) giving you the DIY CTR headlights.
Old Nov 15, 2004 | 07:50 PM
CooBlueDAB's Avatar
actually, I believe the correct model is EJ8
How do I reseal them?
Old Nov 15, 2004 | 07:52 PM
95jizzer's Avatar
make sure you have a rubber cap that covers behind where the bulb is inserted that could cause moisture of water is flipped up from your wheels.
Old Nov 15, 2004 | 07:53 PM
Ej8 represent. What color is your coupe?
https://honda-tech.com/zerothread?id=753457
Old Nov 15, 2004 | 08:13 PM
CooBlueDAB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHC4life &raquo;</TD></TR><TR><TD CLASS="quote">Ej8 represent. What color is your coupe?
https://honda-tech.com/zerothread?id=753457</TD></TR></TABLE>
Ive got the silver, Id post pic, but fearful of theives that hang here. PMed link that has almost everything I did.
Old Nov 15, 2004 | 10:20 PM
blue2ksi's Avatar
go to a autoparts store and look for the silicone sealant ****... seal it up yo
ruiz639
Honda Civic (2001 - 2005)
Dec 15, 2008 08:00 PM
karma28217
Jan 31, 2008 03:05 AM
zachkiro
Oct 4, 2007 03:16 AM
WILD_WILL
Honda Civic (2006 - 2015)
Mar 11, 2007 10:14 PM
hamadiscool
39
Oct 2, 2006 04:58 PM
