Questions on the 4wd 5-door models...
Been thinking about these interesting Civics. I live in Utah...so, there is plenty of snow and mountain roads to have fun on. The Integra (DA9) does pretty well. But, a 4-door relatively light Civic would be fun. Better than a CRV and cheaper. No, I really didn't search. So, I have a few questions:
1. What is the chassis code, which D-series motor was available with it? And the power output?
2. Is an engine swap possible with the 4wd set-up. If not a B-series. Would a turbo D-series be a good idea?
3. Are they available with a manual trans? And is it a good one...will it handle more power(as well as the rear diff)?
4. What type of rear differential is there? If more power was an issue, I wonder if the clutch-pack diff from a CRV could be swapped out.
5. Suspension set-up?
6. Anyone own one of these?
Well, thanks for the help...Anything is appreciated. I think I may have a project to start next spring.
-Jeff
-Jeff
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TEXNTEG »</TD></TR><TR><TD CLASS="quote">1. What is the chassis code, which D-series motor was available with it? And the power output?</TD></TR></TABLE>
have no idea on the chassis code, but given a 88-91 car, motor is a D16A6.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">2. Is an engine swap possible with the 4wd set-up. If not a B-series. Would a turbo D-series be a good idea?</TD></TR></TABLE>
B-series won't bolt to the D-series tranny, so that's out. but folks are running DOHC ZCs and SOHC VTEC motors with the 4wd tranny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">3. Are they available with a manual trans? And is it a good one...will it handle more power(as well as the rear diff)?</TD></TR></TABLE>
yeah, they could be had with a "6-speed," though one of those gears is a superlow granny gear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">4. What type of rear differential is there? If more power was an issue, I wonder if the clutch-pack diff from a CRV could be swapped out.</TD></TR></TABLE>
i have no idea.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">5. Suspension set-up?</TD></TR></TABLE>
again, speaking for 88-91, essentially similar to same years hatch/crx. some differences in rear shocks/springs, but easy to work around.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">6. Anyone own one of these?</TD></TR></TABLE>
http://p196.ezboard.com/bhondacivicwagon
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Well, thanks for the help...Anything is appreciated. I think I may have a project to start next spring.
-Jeff
good luck.
i have no idea.
-Jeff
good luck.
hahaha my friends and I were talking the other night about buying one for a swap. That would qualify as quite possibly the best sleeper car out there. Who would ever think that the civic wagon revving next to you has a ZC turbo...
Good hook up too with the 4WD... if you actually do this put up project thread I would love to see this.
well, we'll see. it's either this or make the integra into a rally-machine/daily-driver.
but, a boosted 4wd civic wagon would be fun. haul some camping stuff in it.
it'd be alot cheaper than buying a new CR-V, which is my other option.
EG81992
Jun 2, 2011 09:11 PM
Black R
11
Sep 29, 2003 11:02 AM
