Help with rear brakes 1988 lude
Old Nov 15, 2004 | 01:44 PM
danmoore80's Avatar
Default Help with rear brakes 1988 lude
I pulled off the rear wheels, removed the calipers, took old pads off, put new ones into place, and WTF now it doesen't go on the rotor. I then walked into the garage, grabed a "C" clamp in order to compress the "you know," only it would not compress. I removed the reservoir cap, and loosened the nipple behind the caliper(I slipped a hose with brake fluid over the nipple prior to loosening to prevent air from getting into the line)but it still will not compress.
I now have learned that these rear calipers don't compress, but rotate.....how exactyl do I rotate them? Thank you for your help.
Old Nov 15, 2004 | 01:52 PM
drdisco69's Avatar
Default Re: Help with rear brakes 1988 lude (danmoore80)
There is a tool for it, looks like a spiked cube with holes in it, thats the easiest way. Or get some needle nose pliers or a screwdriver. Just try stuff.
Old Nov 15, 2004 | 01:53 PM
danmoore80's Avatar
Default Re: Help with rear brakes 1988 lude (drdisco69)
I'll see what I can come up with Thanx for the help!
Old Nov 15, 2004 | 01:56 PM
vtekstorm's Avatar
those calipers are not ment to be compressed you can ruin the caliper like that. u have to turn it. theres a brake tool kit for rear brakes. sure saved my *** a few times. i had a old 86 prelude.
Old Nov 17, 2004 | 09:11 AM
PrettyLude's Avatar
use a screwdriver to turn in the caliper
1SloNeon
Jun 12, 2008 11:16 AM
ultrablackhatch
Jul 30, 2006 09:33 PM
Project_ED8
Honda S2000
15
Jan 14, 2005 07:00 PM
ScootinIntegra
Feb 16, 2004 03:59 AM
