Aftermarket clutch with stock Pressure plate?
Old Nov 15, 2004 | 12:44 PM
specie's Avatar
Default Aftermarket clutch with stock Pressure plate?
I'm looking in getting a CM stage 3 clutch. I had one on my old car and I really liked the clutch. If I recall correctly, CM uses the stock pressure plate and modify them for their application. I was wondering if it's okay to use the stock pp with a CM stage 3 disk. The goal for my setup is around 250whp with nitrous (which will be rarely used) and the car will be rarely abused.
Old Nov 15, 2004 | 07:46 PM
onebad3dr's Avatar
Default Re: Aftermarket clutch with stock Pressure plate? (specie)
i know a couple of guys in orlando fl. that are running 4 puck disks on stock pressure plates and say the clutch holds fine and doesn't slip (the cars are making at least 250 to 300 on nitrous)
Old Nov 16, 2004 | 03:17 PM
m0nkey's Avatar
Default Re: Aftermarket clutch with stock Pressure plate? (onebad3dr)
what kind of setup do they have making that much power?
Old Nov 17, 2004 | 08:54 AM
specie's Avatar
Default Re: Aftermarket clutch with stock Pressure plate? (m0nkey)
anyone else tried this setup? I'm going to order one soon.
I'll be using an ITR pp.
Old Nov 17, 2004 | 09:12 AM
yellowturbo's Avatar
in fact the setup that you should use is an aftermarket double pressure plate with a OEM disc...
The pressure plate hold the power... not the disc... Some disc have better quality than other...
But if your goal is like 250 whp, I would run a good double pressure plate with a OEM Honda disc. I had this setup on my 250 whp D16 and really enjoyed it... If I could run this setup now I would. This is so much streetable than a puck clutch and it hold realllly fine belive me !!
Old Nov 17, 2004 | 05:30 PM
specie's Avatar
Default Re: (yellowturbo)
that came as a surprise. How well has it worked out for you? Just a stock disc?
Old Apr 11, 2010 | 05:38 PM
Brice.Hayden's Avatar
bumping this old thread to see if anyone else does this?
Old Apr 12, 2010 | 12:25 PM
welfarepc's Avatar
get your flywheel machined and install the new clutch.
who ever thinks you cant use a stock PP, is, well, for lack of better words, retarded.
although i think there is an Exedy 3 puck ceramic thin disc clutch. not too sure about that one. LOL
Jimmy
Sep 3, 2006 11:57 AM
DX Hybridizer
Jun 7, 2005 08:46 PM
RTW DC2R
Oct 9, 2003 04:33 PM
B16Hatchcx
Jun 8, 2003 06:59 PM
T3EMSI
Jul 22, 2002 07:46 PM
