steering wheel cut because of the club
Old Nov 15, 2004 | 12:30 PM
sinister357's Avatar
Default steering wheel cut because of the club
my 95 gsr almost got stolen! while i was visiting in milwaukee wi over the weekend, in downtown i parked my car to go clubbing. someone broke into my car (don't know how because there is no damage) and tried to cut the steering wheel with a knife in trying to get the "club" off. luckly they only ended up stealing all of our luggages and left everything else (rims, stereo, cd changer, leather seats, ect...) the only thing i'm complaining about is my steering wheel. there's a cut on it. is there any product i can use to fill of get rid of this cut mark? does any one have a black steering wheel for sale ?(w/o the airbag because mine is fine) thanks in advance.
Old Nov 15, 2004 | 05:55 PM
Default Re: steering wheel cut because of the club (sinister357)
bump...
Old Nov 15, 2004 | 06:34 PM
b18vtek's Avatar
You should be thankful you didn't get your car stolen. But for your steering wheel, go to a junk yard. There should be something you could use. Ever though of a new anti-thief device?
Old Nov 15, 2004 | 06:38 PM
Cabby89's Avatar
Time to go to something like a Sparco or Momo wheel with a detachable setup so you can either hide the wheel or really you should take it with you.
Ohh and damn Im glad my Teg, looks like **** cause Im in Milwaukee all the time.
Old Nov 15, 2004 | 07:47 PM
Default Re: steering wheel cut because of the club (Cabby89)
other then an alarm system i was also thinking of getting one of those locks that attaches just to the clutch pedal. i think that would be alot harder if not impossible to cut through considering where it is. what do you guys think? but so far that club has served it's purpose so i will continue using it for the time being.
Old Nov 15, 2004 | 08:52 PM
a1320addict's Avatar
**** that im gonna get THE BOOT
you know that **** nypd uses if you double park or some ****
Old Nov 16, 2004 | 01:47 PM
i remember seeing some kind of dashboard repair kit out there. do you guys think that might work in the steering wheel?
Old Nov 16, 2004 | 01:50 PM
NightRiderS2K's Avatar
In-N-Out Burger
If it's a deep cut, then NO.
Is it that unbearable that you are this desperate to fix it?
This is a good excuse to get a JDM ITR one nonSRS or the other, they both look good and OEM-like. Unless you want to get rid of your airbag then get a Momo or other similar wheel that's detachable.
Old Nov 16, 2004 | 02:01 PM
Default Re: steering wheel cut because of the club (NightRider-gsR)
yes, it's very noticably ugly. where and how much can i get a jdm itr steering wheel for? how does it look like? is it available in black? i'm not willing to give up the airbag.
Old Nov 16, 2004 | 02:04 PM
In-N-Out Burger
Courtesy of Search...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by *****StEr &raquo;</TD></TR><TR><TD CLASS="quote">$425 plus shipping or $425 picked up. Located in San Francisco.
Old Nov 16, 2004 | 02:06 PM
Redline94LS's Avatar
good luck finding a used one for under $500. i'd just get a thin cover to put over it, unless ur that gung-ho over getting a new wheel all together.
Old Nov 16, 2004 | 02:17 PM
thanks for the pictures NightRider-gsrR. that is an airbag, right? i noticed it didn't have the cruise control button. can that be put on there? would this be a direct bolt on for the gsr? thanks again in advance.
Old Nov 16, 2004 | 02:39 PM
shermanyang's Avatar
wow that sucks...no wonder when i bought my teg from Miltown WI the dude said he never drives it out.
Old Nov 16, 2004 | 03:17 PM
AlxSiR7's Avatar
nah.. thats the jdm momo type r steering wheel. no buttons.. just horns on the side. and yes, and can bolt up to a gsr.
Old Nov 17, 2004 | 05:26 PM
i have found a replacement but was wondering how hard it would be in replacing it. is there any tricks in keeping it aligned? will the airbag be an issue at all? what about the wirings? if anyone has done this, let me know what you think and if ther's any tips you can give. any help is appreciated. thanks in advance.
Old Nov 17, 2004 | 05:29 PM
DC2Slow's Avatar
the top lining for the dc2 doors is only rubber so they brobably just jimmy'd it. Wheel clubs dont work they cut mines 2 try the clutch lock. good luck
Old Nov 17, 2004 | 05:35 PM
rodneyk's Avatar
Its not that hard to replace at all, but i'd recommend finding the instructions on how to disarm and remove the airbag instead of goofing with it.
If you get the JDM Momo airbag wheel, remember that its designed for the updated airbag harness (94-95 is different), so the wiring's a little different. If i remember correctly, canuckmx6 has this wheel on a 95 Teg, just do a search for his post about it.
Good luck!
Old Nov 17, 2004 | 05:40 PM
Default Re: (rodneyk)
how would i disarm the airbag? would pulling the battery plug do it? any instructions on how to get the steering wheel off?
Old Nov 17, 2004 | 05:44 PM
threatcon13's Avatar
New User
Default Re: (sinister357)
Pull off covers on side of steering wheel, then there will be two torx bolts you need to remove, then you can take off airbag module. (be sure to disconnect battery for a couple of minutes before any of this) Remove airbag module and disconnect srs harness, then i believe its a 17mm socket you will need to get the bolt off that holds the steering wheel in. Take that off, then do the reverse to install new wheel/airbag. Its very easy.
Old Nov 17, 2004 | 05:54 PM
Default Re: (Threatcon13)
thanks Threatcon13. would you happen to know what size those torx bolts are?
Old Nov 17, 2004 | 08:55 PM
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sinister357 &raquo;</TD></TR><TR><TD CLASS="quote">thanks Threatcon13. would you happen to know what size those torx bolts are?</TD></TR></TABLE> Unfortunately I don't, but you can just pick up a generic torx set from autozone, that is what I did. it's a small size.
Old Nov 24, 2004 | 07:05 PM
Default Re: (threatcon13)
finally got my steering wheel replaced. my car is a 95 and the replacement was from a 97 so the wirings are a little different - i couldn't use the airbag or cruise control that came with the "new" replacement. had to use the originals plus the wiring brackets but other then that, everything was a direct fit. i'll just save the airbag in case i should ever need it - just replace the plug and it should be ok. anyways, just for reference, the trox size for the airbag was t30 and the nut that holds the steering wheel is a 19mm.
Old Nov 24, 2004 | 07:08 PM
ernald711's Avatar
be grateful, cause that's what happened to me
Old Nov 24, 2004 | 07:18 PM
phantomx_teggy's Avatar
thats so beautiful..wish i had the cash to buy it right now
Old Nov 24, 2004 | 09:06 PM
dt4life's Avatar
drooling.....NICE WHEEL
