5spd tranny is crap when cold, any suggestions?
Old Nov 15, 2004 | 11:53 AM
salvageland's Avatar
Default 5spd tranny is crap when cold, any suggestions?
HI, I have a 2000 Base lude 5spd, and everymorning when I start the car, reguardless if I let it warm up or not it's hard to shift into 1,2,3 gears. and when downshifting to these gears I have to double clutch or is grinds slightly. When the tranny warms up, or when I drive for like 5-10minutes in gear, everything smoothens out and it shifts perfectly.
I bought the car when it had 73K I changed the oil with HOnda MTF at 73K now it's at 76K.
MY QUESTION:
Should I replace the tranny fluid with GM Syncromesh Friction Modified? or is there some other alternative that I can do.
Thanks in Advance
Old Nov 15, 2004 | 01:40 PM
xludexgenx5's Avatar
Default Re: 5spd tranny is crap when cold, any suggestions? (salvageland)
I had Redline MTL and I had the same problem when it was cold, After I switched over to syncromesh if worked fine... so may wanna give that a try,..
Old Nov 15, 2004 | 03:37 PM
Two_K Si's Avatar
Default Re: 5spd tranny is crap when cold, any suggestions? (xludexgenx5)
Maybe give a full synthetic trans fluid a try, such as motul. I have used pennzoil synchromesh in my trans, and cold shifting problems are no more. But i plan on trying the motul fluid when it is time to replace the fluid.
elly7b
Dec 4, 2013 09:52 PM
GuCCi_GSR
May 13, 2005 09:41 PM
