Drag Wheels (size question)
Old Nov 15, 2004 | 11:37 AM
done's Avatar
Default Drag Wheels (size question)
how wide can i go? and what offset will work well..
I want to run 24.5"x8 Mickey Thompsons
Can i go any smaller then a 15? even with spacers??
Old Nov 15, 2004 | 11:44 AM
Jon D's Avatar
Default Re: Drag Wheels (Jordo)
I think you'd get a better response in the Drag forum
.....or pm Pete, (itr206)
Old Nov 15, 2004 | 11:46 AM
00ITR #543's Avatar
24.5x8x15 are a good size to run with.. You can also go as wide as 9.2. Can't go smaller than a 15" rim. Spacers are required as with most drag wheels to clear the caliper.
I run the 24.5x8x15 MHs. They stick out about 2", but turning is not a problem. Just have to raise the car a little bit.
Old Nov 15, 2004 | 11:54 AM
PM-Performance's Avatar
Default Re: Drag Wheels (00ITR #543)
24.5x8.5x15 isnt all that huge. you will need to jack the front a tad though.
you can get them on stock R wheels, but id try to atleast get x7's
you got stage 3's or better? If not get some , because you WILL break them
Old Nov 15, 2004 | 12:01 PM
GokuSSJ4's Avatar
Default Re: Drag Wheels (itr206)
you can try out even 15x8x22's on a 15x8 (spacer build into the wheel) bogarts wheels which weight near 7-8lbs. each. unless you start to push more the 200whp then i would go with a bigger slick.
the only way to run a smaller size of wheels is changing the itr 5 lug to a gsr brakes. which allow you to either run bogarts 13x8 (with spacers build into the wheel) or even 14x5.5 or try to find 13x8 lenzo wheels or stock EK's steel wheels which will barly clear the gsr calipers. Its also best if you get longer wheel studs since with the spacer you will need the xtra length for safety reasons.
Old Nov 15, 2004 | 12:05 PM
Aquafina's Avatar
Default Re: Drag Wheels (GokuSSJ4)
Jordo already to hit up the midnight "street races" at MAM....
Old Nov 15, 2004 | 12:10 PM
done's Avatar
Default Re: Drag Wheels (Aquafina)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina &raquo;</TD></TR><TR><TD CLASS="quote">Jordo already to hit up the midnight "street races" at MAM....</TD></TR></TABLE>
MAM?
i not ready yet .. should be only a few days though.
Things i lack are axles and wheel/slick combo
Old Nov 15, 2004 | 12:38 PM
i would worry about getting used to it on street tires first and getting the tune down and the motor broken in. But yes you will need axles. **** id go right to stage 5's. Better safe then sorry.
Old Nov 15, 2004 | 12:40 PM
done's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">i would worry about getting used to it on street tires first and getting the tune down and the motor broken in. But yes you will need axles. **** id go right to stage 5's. Better safe then sorry. </TD></TR></TABLE>
how much different is it going to be then when i had it on the stock motor??
The car will be street tuned with wideband when it 1st comes out the shop..
Im going to setup a dyno time soon once i get the car out.
Old Nov 15, 2004 | 12:46 PM
its gonna be tons different becuase im assuming you are gonna up the boost. Trust me you will have a hard time keeping it under control .**** 350whp on the street was a chore and a 1/2 then i went to almost 450whp on the street and that takes some skill and seat time. Your not even gonna know what to think when you start pushing some power. Do yourself a favor get used to it in incraments.
Old Nov 15, 2004 | 12:48 PM
done's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">its gonna be tons different becuase im assuming you are gonna up the boost. Trust me you will have a hard time keeping it under control .**** 350whp on the street was a chore and a 1/2 then i went to almost 450whp on the street and that takes some skill and seat time. Your not even gonna know what to think when you start pushing some power. Do yourself a favor get used to it in incraments. </TD></TR></TABLE>
man im soo scared to blow the motor again.. Im running eagle rods..
I probadly wont even turn the boost controller on
Old Nov 15, 2004 | 01:27 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jordo &raquo;</TD></TR><TR><TD CLASS="quote">man im soo scared to blow the motor again.. Im running eagle rods..
I probadly wont even turn the boost controller on</TD></TR></TABLE>
Yeah you will. You know you will.
Old Nov 15, 2004 | 01:49 PM
What does Eagle Rods have to do with it?
If you have it tuned right and use your head on maintenance it shouldnt be much of an issue.
PS if your scared to break it, you shouldnt be asking about wheel and slick combos to drag race. YOU WILL BREAK IT&gt; trust me.
Running925
Mar 7, 2008 05:30 AM
playahwitgame
Aug 8, 2006 11:26 AM
VisualAutoMotoring
May 25, 2005 11:47 PM
vtecb20coupe
Feb 7, 2004 01:15 AM
