Light on my dash
When I accelerate, this light on my dashboard goes on:
When I stop accelerating, the light stops. This light normaly lights on when I apply my e-brake. Is there any other function, like oil-related or so? Or do I have only some bad wires to the light?
Thanks,
Petr
Thanks,
Petr
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike »</TD></TR><TR><TD CLASS="quote">Check the level of your brake fluid.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike »</TD></TR><TR><TD CLASS="quote">Check the level of your brake fluid. The light will also go off if it's low.</TD></TR></TABLE>
Yup! Brake fluid sloshing around will cause that light to go on/off. The cap of the brake fluid reservoir has a float that is the sensor for low brake fluid.
It "could" be a bad sensor on your e-brake... but I never heard of one doing that.
-Chris
-Chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by totsie7944 »</TD></TR><TR><TD CLASS="quote">yea dude check ur oil.</TD></TR></TABLE>
tranny fluid too
tranny fluid too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by People_Mover »</TD></TR><TR><TD CLASS="quote">
tranny fluid too
God Bless
tranny fluid too
</TD></TR></TABLE>God Bless
What MugenGuru said.
I had that happen once in the Si after changing pads at the track. The brake fluid was low and the light went off every time i accelerated. The light went off each time i braked as the fluid slushed in the reservoir. on the bright side, who needs brakes when accelerating?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petrv »</TD></TR><TR><TD CLASS="quote">When I accelerate, this light on my dashboard goes on:
Thanks,
Petr</TD></TR></TABLE> thats your e-brake
Thanks,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow_Em1 »</TD></TR><TR><TD CLASS="quote"> thats your e-brake
Thanks, Sherlock.
Thanks, Sherlock.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo »</TD></TR><TR><TD CLASS="quote">Thanks, Sherlock.</TD></TR></TABLE>
I bet he had to call watson for that one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR »</TD></TR><TR><TD CLASS="quote">watson would suck off sherlock once in awhile </TD></TR></TABLE>
J00've been watching j00r ghey pr0n again...haven't j00?
it explains the pink p00dles though....
that is his e-brake light, but it is only supposed to be on when the e-brake is on. in his case, the light turned on while accelerating. i don't know if you were being sarcastic or not, but if so, you suck at it.
btw, it's low brake fluid.
dude this guy is right.....
BigZ88
Feb 21, 2005 09:17 PM
