S2000 Oil Filter
Old Nov 15, 2004 | 11:02 AM
LowFlyin''s Avatar
Default S2000 Oil Filter
Has anyone put a S2000 oil filter on their H22?
I have one on my '01 SH, but I haven't had it out on the track yet. I know all the V8 guys always say get the biggest oil filter that will fit on you car. The only thing I'm worried about is, with the larger capacity of the S2K filter I'm worried that'll I'll get the oil starvation problem when turning left at the track. Other than that, it fits and seals up great.
Old Nov 15, 2004 | 11:10 AM
Shakes's Avatar
space cadet
Default Re: S2000 Oil Filter (LowFlyin')
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LowFlyin’ &raquo;</TD></TR><TR><TD CLASS="quote">Has anyone put a S2000 oil filter on their H22?
I have one on my '01 SH, but I haven't had it out on the track yet. I know all the V8 guys always say get the biggest oil filter that will fit on you car. The only thing I'm worried about is, with the larger capacity of the S2K filter I'm worried that'll I'll get the oil starvation problem when turning left at the track. Other than that, it fits and seals up great.</TD></TR></TABLE>
if you dont have an oil pressure gauge then i HIGHLY suggest getting one, especially if you are going to run a larger filter. put the gauge in the car and then watch it closely, or have a friend watch it while you take a few good turns. if you arent running lower then normal then i would say keep it. but do a comparison with both filters to make sure. also are you running a honda filter or other manufacturer?
Old Nov 15, 2004 | 11:26 AM
LowFlyin''s Avatar
Yes, it is a OEM filter...but I don't have an oil pressure gauge.
Old Nov 15, 2004 | 11:33 AM
bb6h22a's Avatar
I've been usuing an s2000 filter for a long while on the street and track - no problems.
Old Nov 15, 2004 | 12:17 PM
md23vtec's Avatar
I would reccomend using the s2000 filter also I have been using them for a few years now. Ihave had no problems. Honda stopped making the olderstyle and is using the smaller filters they both work I just feel more comfortable with the s2000 style personal preference. Also didnt notice and differnce in trying the filters with oil pressure so either way u should be good 2 go
Old Nov 15, 2004 | 12:25 PM
hOndafienD 04's Avatar
call me a newbie but whats the advantage in using a larger oil filter?
Old Nov 15, 2004 | 12:32 PM
md23vtec's Avatar
Default Re: (hOndafienD 04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOndafienD 04 &raquo;</TD></TR><TR><TD CLASS="quote">call me a newbie but whats the advantage in using a larger oil filter?</TD></TR></TABLE>
Honestly there is none Oil pressure does not change with the standard or s2000 filter.
Old Nov 15, 2004 | 12:39 PM
then wats the reasoning behind the use?
Old Nov 15, 2004 | 12:43 PM
LowFlyin''s Avatar
Piece of mind.
A bigger filter has a larger filtering surface, so you should get better filtration.
Old Nov 15, 2004 | 12:51 PM
ok what happens if you use a smaller filter?
Old Nov 15, 2004 | 01:31 PM
LudeyKrus's Avatar
So the S2000 filter is smaller than the OEM Honda Prelude filter??
I was lookin for a smaller filter a while back; it SHOULD give a slight bump in oil pressure.
Old Nov 15, 2004 | 01:39 PM
Monkey Fing a Coconut's Avatar
Default Re: (LudeyKrus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">So the S2000 filter is smaller than the OEM Honda filter??
I was lookin for a smaller filter a while back; it SHOULD give a slight bump in oil pressure.</TD></TR></TABLE>
the s2k is the older model looking filter which is shorter but fatter, the newer non-s2k filters are longer but skinnier
Old Nov 15, 2004 | 01:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">I was lookin for a smaller filter a while back; it SHOULD give a slight bump in oil pressure.</TD></TR></TABLE>
ok good.....thanx
Old Nov 15, 2004 | 04:49 PM
md23vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOndafienD 04 &raquo;</TD></TR><TR><TD CLASS="quote">then wats the reasoning behind the use?</TD></TR></TABLE>
personal preference
Old Nov 15, 2004 | 04:59 PM
i doubt its just that...but ok.
Old Nov 15, 2004 | 05:08 PM
md23vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOndafienD 04 &raquo;</TD></TR><TR><TD CLASS="quote">i doubt its just that...but ok.</TD></TR></TABLE>
NO! That is it, I was bored at work and did an oil pressure test since your so smart you already know the results, but for those of you who dont know it was the fairly same. the s2000 filter is alot wider so it has higher campacty to filter more, not nessacary in any aspect or honda would have reccomended them for the prelude also not just the s2000
Old Nov 15, 2004 | 05:12 PM
Default Re: (md23vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by md23vtec &raquo;</TD></TR><TR><TD CLASS="quote">
NO! That is it, I was bored at work and did an oil pressure test since your so smart you already know the results, but for those of you who dont know it was the fairly same. the s2000 filter is alot wider so it has higher campacty to filter more, not nessacary in any aspect or honda would have reccomended them for the prelude also not just the s2000</TD></TR></TABLE>
i never said i was smart...i just thought there was more of an in depth reason why some1 would rather use the larger filter...sorry if you took it the wrong way
so now i know the results were the same, so now i know its not worth to use the bigger filter...
Old Nov 15, 2004 | 05:19 PM
bb6h22a's Avatar
More surface area = always a good thing. What I don't like about the dinky, can-o-beans filters that Honda unfiormally reccomends is that I don't like the idea of minimizing , or even reducing, the efficency of my oil filter to reduce/catch/stop small dirt partciles and other misc. **** from getting into my engine/oil supply/oil jets, etc. It's a small price to pay, for added piece of mind; if Honda puts a different, more efficent filter on their most developed "sports car" then I'd say there's good reason to use that filter, in an application where your car sees 60-70% wide open throttle, lateral loads close to, or slightly over 1 G in addition to ambient and operataional temps in, what some would classify as "extreme" for 6- 8 hours a day.
So, you're right, it's my preference to minimize the risk of chucking my motor, by using a "better" filter than the one intended for Mrs. Jones and here groecery getter.
Old Nov 15, 2004 | 05:28 PM
md23vtec's Avatar
Default Re: (bb6h22a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb6h22a &raquo;</TD></TR><TR><TD CLASS="quote">
So, you're right, it's my preference to minimize the risk of chucking my motor, by using a "better" filter than the one intended for Mrs. Jones and here groecery getter.</TD></TR></TABLE>
so now i know the results were the same, so now i know its not worth to use the bigger filter...</TD></TR></TABLE>
Nope I didnt take it the wrong way its honda-tech relax , It does have bigger filter (s2000) If I get bored again I'll cut the filters and unravel the filtering element inside the filter and put up mesurements
Old Nov 15, 2004 | 05:29 PM
sounds like a plan...
duf2570
Apr 27, 2014 08:23 AM
shawnlee250
Honda Civic (2001 - 2005)
Aug 3, 2011 12:54 AM
xintegr
Aug 29, 2007 06:46 AM
rohec04
Aug 7, 2007 10:11 AM
