bulb change - 99 oddesy clock
The clock bulb is out on my 99 oddesy. How do I go about removing the clock so that I can change the bulb?? Thanx
Modified by WAYNEBUILT at 12:38 PM 11/21/2004
HERE YOU GO: YOU MUST REMOVE THE BEZEL AROUND THE RADIO AND THEN THE TRIM AROUND THE CLOCK ITSSELF JUST ENOUGH TO GET YOUR HAND BEHIND IT. THIS WILL ALLOW YOU TO ACCESS THE BULB WHICH IS AROUND $14.00
