Toda A's vs.Toda B's
Do the Spec A's like compression like I've heard the Spec B's do? I see that the cam specs are way different but what it the "butt dyno" difference between the Spec A's and the Spec B's if compared on the same engine.
Spec As are great with about 11.5:1 CR.
Any cam with a large amount of duratoin and overlap is going to require
much higher static compression because the dynamic compression will go
down.
down.
Spec B's show their true colors with high compression.
Spec A's work great on stock engines.. but shine even more with high compression.
This topic has been covered many times. It's all a matter of opinion.
jeremy.
Nov 3, 2003 05:28 AM
blazin
Jan 6, 2002 07:31 PM
