Is my CRX OBD 1? So does that mean so is my SiR-I B16A1?
Old Nov 15, 2004 | 07:09 AM
BigPlansNoMoney's Avatar
Default Is my CRX OBD 1? So does that mean so is my SiR-I B16A1?
As the question states...
Old Nov 15, 2004 | 07:21 AM
crx_88_si's Avatar
Default Re: Is my CRX OBD 1? So does that mean so is my SiR-I B16A1? (Justin_Bradley)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin_Bradley &raquo;</TD></TR><TR><TD CLASS="quote">As the question states...</TD></TR></TABLE>
um.. no ?
Old Nov 15, 2004 | 08:01 AM
Default Re: Is my CRX OBD 1? So does that mean so is my SiR-I B16A1? (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">
um.. no ? </TD></TR></TABLE>
Are you going to explain why not?
Old Nov 15, 2004 | 08:03 AM
crx_88_si's Avatar
Are you going to explain why not?</TD></TR></TABLE>
Nope. If I were to explain it to you, you wouldn't understand it. and if you did, then you could have looked for yourself, and not asked..
so again.
No, its not obd-1
Old Nov 15, 2004 | 08:45 AM
DaX's Avatar
DaX
Loved
Community Favorite
Quick check...look at the ECU. What is the code on the ECU? If it's a PR3 or a PW0, it's OBD-0. If it's P08-J, P28, P30-A, P30-O, P30-G, P61, P72, or P72-J, it's OBD-1.
Old Nov 15, 2004 | 08:59 AM
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">Quick check...look at the ECU. What is the code on the ECU? If it's a PR3 or a PW0, it's OBD-0. If it's P08-J, P28, P30-A, P30-O, P30-G, P61, P72, or P72-J, it's OBD-1.</TD></TR></TABLE>
So a CRX can be either/or?
Old Nov 15, 2004 | 09:06 AM
I Have an STD's Avatar
wrenchin'
Default Re: (Justin_Bradley)
the 1sg obd1 passenger cars were produced in 92. the last year the crx was built was 91. so no yer car is not obd1
Brett
ps, NEWB
Old Nov 15, 2004 | 09:23 AM
Default Re: (I Have an STD)
So since an SiR I came from a 90-91 CRX, it is pre-OBD, or OBD-0, right?
Old Nov 15, 2004 | 09:33 AM
Deetz's Avatar
Crazy Honda Guy
Default Re: (DaX)
Be carefull, i have a number of pr3 ecu's that come in obd1 as well. People always just assume.
All North American crx's came non obd from factory. Many people have done obd1 conversions, and even the odd obdII.
Old Nov 15, 2004 | 09:47 AM
speedhatch's Avatar
that is correct
Old Nov 15, 2004 | 11:43 AM
Nov!ce's Avatar
What Deetz said. It's obd0, or non-obd, unless there has been a conversion.
Old Nov 15, 2004 | 11:49 AM
fireant's Avatar
Default Re: (Nov!ce)
and just to clarify, non-OBD is also referred to as OBD0
Unless its been modified or there was a serious fluke, any stock usdm crx 88-91 ecu should be OBD0
HondaGuy4Life
Jul 8, 2008 06:17 AM
kotic
Jan 8, 2008 04:36 PM
RCautoworks
28
Jul 28, 2006 11:29 AM
ppfalcon
Sep 28, 2005 10:31 AM
builthatch
Aug 17, 2005 05:37 AM
