Slicks with rims, Drag Radials with rims, Toda cam Gears, used stock b16a2 valves, springs, retainer
I need to move out the following items, I will provide a shipping quote if you are intersted in any of the items below just send me your zip code, i will post pictures this evening.
I have new set of TODA Adjustable Cam Gears for sale for any B-Series motor, These were installed on my new motor but prior to being installed into the car i decided to run the stock cam gears instead since i was going turbo.
SOLD!!!!!!!!
Toda cam gear pictures, I will have the other pictures posted shortly.
B16a2 complete stock valves setup with 42000 miles on it.
16 Stock B16a2 Valves
Complete set of stock valve springs
Complete set of stock retainers
New set of Valve guide seals
100 OBO.
New endyne Bosh Fuel pump for any b series, great for a boosted honda. Will fit in the tank with some modification to the fuel pump holder or great for external use as well.
80.00 OBO
Also have a pair of 22x8x15 MT ET Drag Slicks with 4 runs on them. These are basically new, The SLicks are mounted on a set of Enkei RSF-2 15X6 RIMS with a 4x100 bolt pattern. These slicks are perfect for an All motor, or turbo setup.
Asking 385.00 OBO.
Pics of 22x8x15 MT ET Drag Slicks with 4 passes on them, mounted and balanced on 15x6 Enkei RSF-2 Rims
I have a set of 205-50-15 BFG G-Force Drag Radials mounted on a pair of ATS rims 15x7 with a 4x100 bolt pattern they weight 11.5 lbs each. These have about 50% Tread life left.
Asking 320.00 OBO.
Also have my stock Michelin tires off my 99 SI 195/55/15, two have approx 40% tread left and the other two have 95% tread left. I changed out these tires for a set of wider Falken tires. I want these out of my garage i need the room.
Asking 150.00 OBO.
Comptech SS test pipe for 99-00 Civic SI. It will fit other year civics.
Asking 100.00 OBO.
You can email at support@fipracing.com for questions or pictures.
Modified by fipracing_com at 9:19 PM 11/18/2004
Modified by fipracing_com at 10:14 PM 11/18/2004
Modified by fipracing_com at 10:09 AM 11/20/2004
Modified by fipracing_com at 11:11 PM 12/4/2004
SOLD!!!!!!!!
100 OBO.
80.00 OBO
Asking 385.00 OBO.
Asking 320.00 OBO.
Asking 150.00 OBO.
Asking 100.00 OBO.
Pics of Drag Radials 205-50-15 with approx 50% Tread left mounted and balanced on 15x7 ATS Rims.
Also pics of 22x8x15 MT ET Drag Slicks with 4 passes on them, mounted and balanced on 15x6 Enkei RSF-2 Rims
Modified by fipracing_com at 10:11 PM 11/18/2004
Modified by fipracing_com at 10:15 PM 11/18/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 »</TD></TR><TR><TD CLASS="quote">Buy this man's ish
