91 Legend engine swap question
I just recently aquired a 1991 legend. I don't know much of their engines but the d4 light on the shifter panel is blinking when the engine is started no matter what gear it is in. It might be a transmission problem. Should I just do an engine swap? It has 160,000 miles on the current engine/transmission. If so, what type of engine would work best? C32A (3200cc), C32A1 (3206cc), J32A from CLS, J32A2 from 3.2 TLS?
imo i wouldnt waste money on a swap for the legend. there are plenty of ways to spend that money.
sounds like a VSS problem, which isnt unusual considering your mileage.
read this and see what you can come up with
phew, at least you dont know what you are talking about, or else i would have had to try and explain legend engine swaps with you.
keep the engine, read up in the performance section on http://www.acura-legend.com/vbulletin
and yea, your problem is the VSS
CHAMPION68
Dec 28, 2017 06:18 AM
